Layer / Styles functionality
All  1-5  6-12
9245.6 In reply to 9245.5
Hi Shane,
> This is a good one I wasn't aware of as my MacPro track pad was not setup correctly. I use
> a table on my desktop machine, is there anyway to do this without the right click? Maybe
> Ctrl +Click could be the standard? It seems to be the standard for changing color, locking and filtering.
I'll add this Ctrl + Click behavior for the next v4 beta to do the same as right click there.
> Cinema 4d has some nice features in their layer system. It uses small icons so the
> functionality is always visible.
The problem with having so many things visible is it takes longer to see what's going on and it's a little more difficult to target things. I've tried pretty hard to avoid having so many columns of controls all visible at once like that.
9245.7 In reply to 9245.6
Michael, I just wanted to say that I appreciate the simplicity of the interface you've designed. I don't like software that shows you everything at a glance. I know you wrote most of Rhino, but I get a little overwhelmed when I have to use it and I absolutely love the fact that MoI stands in the face of overly complicated programs. And I'm not arguing shane's request (don't get me wrong).
I also know that I'm preaching to the choir here. ;-)
9245.8 In reply to 9245.7
Hi Micheal, I completely agree that I would not want to complicate the interface, it works very good as-is.
I really appreciate the thought that you put into it vs just throwing in a bunch of buttons / commands. Things like blend, boolean, trims etc. work on all objects it really simplifies my workflow and shortcuts.
Adding the Ctrl + Click behavior to do the same as right click will be great. Thank you.
I am going to get greedy and ask if Ctrl + Clicking on a style name can behave the same as it does in the properties panel and open up the naming dialogue?
-Shane
rendering . animation . oddlyeven.com
9245.9 In reply to 9245.8
Hi Shane,
Just to make sure - you're talking about in the Edit Styles dialog, making Ctrl + Click do the same thing as right-click does there currently?
9245.10 In reply to 9245.9
Hi Michael, what I am suggesting is in the styles directly without having to go into edit styles. See attached screenshot.
-Shane
9245.11 In reply to 9245.10
Hi shane, sorry no I can't do that one yet because I have not yet completed the full design for the scene browser and I don't know yet the full set of functions that a scene browser item will need to support.
9245.12 In reply to 9245.11
Thanks Micheal, your shortcut pointers and adding some of the Ctrl+Click behavior will be very helpful.
-Shane
Show messages: All  1-5  6-12
