Dark Gray Theme
 1-13  14-33  34-53  54-62
9242.54 In reply to 9242.53
Hello,
I am new here!! Hello everyone!
Is this Dark Gray Theme here available for the final version?
Thanks!
E.
9242.55 In reply to 9242.54
Hi eduarcor, I don't know about this one but there are a couple other dark UI moi.css files set up for use with v4 here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10199.3
9242.56 In reply to 9242.55
Awesome, thanks Michael!
9242.57 In reply to 9242.56
Hi guys where can I recover the gray theme ... I'm interested in installing it too.
can you explain to me how to do it?
9242.58 In reply to 9242.57
Hi Tony,
There are some moi.css files linked to here:
To install it you would put one of those in place of the standard moi.css file that is in the UI subdirectory of a MoI installation.
9242.59 In reply to 9242.58
Hello Michael,
can you advise please how to change the color and style of the main frame that divides the right / left / top / 3D views from each other.
I used Cody's dark theme which was really nice but since the css is not customized for v4 I would use the css files you modified for v4 of the dark themes from other users, but there the frames are default light grey.
Axel
Size: 83.7 KB, Downloaded: 156 times, Dimensions: 1858x1048px
9242.60 In reply to 9242.59
HI Axel, that's one of the few remaining areas that is still drawn by a bitmap image instead of drawn procedurally by code. So to modify those colors you need to edit the file ViewportForeground.png in the UI folder using an image editor.
9242.61 In reply to 9242.60
thank you for your advise.
Best regards,
Axel
9242.62 In reply to 9242.61
...what a difference with a dark frame. It was very easy and the dark theme looks much better in my opinion with the dark frames. It fits nicely.
Cheers,
Axel
Size: 82.7 KB, Downloaded: 285 times, Dimensions: 1894x1045px
Show messages:  1-13  14-33  34-53  54-62
