Dark Gray Theme
 1-5  6-25  26-45  46-62
9242.46 In reply to 9242.45
is that for the latest MOI version as well and originally the one from Cody?
Cheers,
Axel
9242.47 In reply to 9242.46
Yep that works fine for the V 4 beta ;)
Sorry for the late test : i have put the minimum! Because I had a previous little Tools Bar sufficient for me... ;)
In French of course for me! ;) https://moiscript.weebly.com/trucs-astuces.html
and so...
EDITED: 28 Sep 2020 by PILOU
9242.48
Hi All,
Is there a version of Cody's dark UI that works with the final release of v4?
If not, what are the main differences if I wanted to burn the time to rebuild and make it work?
Thanks for the help!
+1 for a pinned thread on theming that gets updated
+1 for an 'official' dark theme for Moi
9242.49 In reply to 9242.48
Hi Lavellotron,
You'd do a diff between the default v3 moi.css and the modified version, and then apply the same changes onto the moi v4 moi.css file.
You can't just copy the entire v3 UI onto v4 because then you'll be missing the changes in moi v4.
9242.50 In reply to 9242.49
Good tip, Michael. Thank you.
9242.51 In reply to 9242.50
I'm on macOS. Oddly, when I replace or update icons and the moi.css, nothing appears to change.
I'm modifying the files located here:
/Applications/MoI\ v4.app/Contents/Resources/ui
Is this the correct location?
9242.52 In reply to 9242.51
Hi Lavellotron,
Yes, that is the correct location, the main file to edit is moi.css located there, there are a couple of dark versions of moi.css here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10199.3
The PNG image files for most of the buttons are in an "icons" subdirectory underneath ui.
Did you have MoI open while you were making changes? They won't show up until you close MoI and relaunch it.
9242.53 In reply to 9242.52
Thanks, Michael.
No, what happened was the magic of dock shortcuts linking to the app in Downloads and not the one I dragged into Application. Doh!
Thanks, happy camper now.
9242.54 In reply to 9242.53
Hello,
I am new here!! Hello everyone!
Is this Dark Gray Theme here available for the final version?
Thanks!
E.
9242.55 In reply to 9242.54
Hi eduarcor, I don't know about this one but there are a couple other dark UI moi.css files set up for use with v4 here:
9242.56 In reply to 9242.55
Awesome, thanks Michael!
9242.57 In reply to 9242.56
Hi guys where can I recover the gray theme ... I'm interested in installing it too.
can you explain to me how to do it?
9242.58 In reply to 9242.57
Hi Tony,
There are some moi.css files linked to here:
To install it you would put one of those in place of the standard moi.css file that is in the UI subdirectory of a MoI installation.
9242.59 In reply to 9242.58
Hello Michael,
can you advise please how to change the color and style of the main frame that divides the right / left / top / 3D views from each other.
I used Cody's dark theme which was really nice but since the css is not customized for v4 I would use the css files you modified for v4 of the dark themes from other users, but there the frames are default light grey.
Axel
Size: 83.7 KB, Downloaded: 156 times, Dimensions: 1858x1048px
9242.60 In reply to 9242.59
HI Axel, that's one of the few remaining areas that is still drawn by a bitmap image instead of drawn procedurally by code. So to modify those colors you need to edit the file ViewportForeground.png in the UI folder using an image editor.
9242.61 In reply to 9242.60
thank you for your advise.
Best regards,
Axel
9242.62 In reply to 9242.61
...what a difference with a dark frame. It was very easy and the dark theme looks much better in my opinion with the dark frames. It fits nicely.
Cheers,
Axel
Size: 82.7 KB, Downloaded: 285 times, Dimensions: 1894x1045px
Show messages:  1-5  6-25  26-45  46-62
