Recessed Lettering on a Cylinder
All  1-7  8-9
924.8 In reply to 924.5
After you project the letter curves, if you trim your original surface with them, you can extrude the new letter surfaces using *Set dir* , *Cap ends* and *Both sides*
to create a cutter that will boolean out from the original object at a consistent depth, while following the contour of the surface.
jdkjewelry3d.blogspot.com
924.9
Excellent! I hope these kind of tips find their way into the MoI documentation :)
Ed
Show messages: All  1-7  8-9
