Recessed Lettering on a Cylinder
All  1-5  6-9
924.6
there is a free download for curving text www.deskam.com go to downloads then {"desk engrave" it's free hope this will help it will save as a dxf or g code
924.7 In reply to 924.6
the only detail is that you can't put it inside Moi :)
924.8 In reply to 924.5
After you project the letter curves, if you trim your original surface with them, you can extrude the new letter surfaces using *Set dir* , *Cap ends* and *Both sides*
to create a cutter that will boolean out from the original object at a consistent depth, while following the contour of the surface.
jdkjewelry3d.blogspot.com
924.9
Excellent! I hope these kind of tips find their way into the MoI documentation :)
Ed
Show messages: All  1-5  6-9
