Is there a way to import curves from Maya to Moi?
All  1-4  5-9
9231.5 In reply to 9231.4
9231.6 In reply to 9231.1
I guess one other possible thing is maybe you have to be in some kind of particular selection mode with the curves selected when you do the Maya export?
9231.7
Thanks for the replies, so I've figured it out. In maya's plugin manager you have to turn on iges.mll and in the export select IGESExport with the curves selected in object mode. The issue I was having is that without turning on that plugin, maya already provides you and IGES export option but its called IGES_ATF Export. The windows explorer refers to both as IGES files but the one that works is .iges while the other is just .igs
Size: 15.6 KB, Downloaded: 42 times, Dimensions: 898x78px
Size: 17.6 KB, Downloaded: 41 times, Dimensions: 913x87px
Size: 24 KB, Downloaded: 43 times, Dimensions: 407x395px
9231.8 In reply to 9231.7
Hi Austin, that's kind of tricky to get it to work! I'm glad you have it solved now and thanks for posting how to do it.
Hi Austin,
Which version of Maya are you using?
Show messages: All  1-4  5-9
