Blend Issue: trying to blend the connection between two objects
All  1  2-7
9229.2 In reply to 9229.1
Select big surface cylinder : Edit / Join
Select little surface cylinder : Edit / Join
Select 2 open circumferences : Construct/ Blend
et voilĂ  :)
9229.3 In reply to 9229.1
Hi FED, it looks like you have hidden too many things - you want to hide any curves in that spot so you can select edges but you've hidden both the curves and the edges as well. You don't want to hide the edges since those are what you need to select.
I'll make a demo video showing the steps.
Message 9229.4 deleted 25 Jan 2019 by BEMFARMER
9229.5 In reply to 9229.1
Hi FED, here's a demo video showing the steps after loading your file.
First thing is there is too much hidden - you need to select edges for your blend but you have hidden the edges.
So step 1 is to use Edit > Hide to show hidden objects.
Now there are some curves that are in the way - notice how those are separate objects of their own, I can just drag them away unlike the trimming edge of the surface. Also note that when I select them the object type indicator in the upper right corner says that it is a curve object (it will say either "Curve or Closed crv") when I select it, it does not say it is an edge.
So get those out of your way, here I just dragged them away but you can hide or delete them also.
Then you need to select the edges and run Construct > Blend.
Here's the video:
Hope this helps!
Michael's video is more in deepth than mine! ;)
EDITED: 26 Jan 2019 by PILOU
9229.7 In reply to 9229.5
Hi Michael-
Thank you so much for your patience, time and great video!!!!
I truly love MOI and you have created the best 3D modeling program!!!!!
I have so much fun designing and really feel my creative flow.
Again, thank you for taking the time to answer my blend problem.
Best,
FED
Show messages: All  1  2-7
