Circular Array question
All  1-5  6-8
9228.6
I think I understand the reasoning and I am all in for a more natural workflow with no extra steps :) There is no real reason for me to modify anything, since MoI gave me other options to do what I had in mind. But I really appreciate the option to change array behavior and your in depth answer, as always. Thank you! :)
An another cool method (with my favorite command Line-line :)
Make your circular Array anywhere in normal Plane
Then Use the Transform / Orient / Line-Line (with Scaling none)
(Taking the Center of array as first point, a point of your object on the same plane on the good direction!!!
and a point on the target surface , and the second target point on this same plane of this target suface)
Works of course from any plane to any other plane! ;)
et voilĂ ! ;)
The Helpers lines tools tips text can help you!
Here the "Z negative" vertical Helpers direction on the target surface!
Of course for your case it's trivial because all will be on the same plane! ;)
The power of the Line-line astonishes me at each time! :)
EDITED: 25 Jan 2019 by PILOU
9228.8
Highfives Pilou! I really love your approach. I will experiment some more with orient and help lines.
Well... I learned so much today. All thanks to Circular Array! And all of you, of course. ^__^ *applause*
Show messages: All  1-5  6-8
