Selecting units on STL export
All  1  2-4
9224.2 In reply to 9224.1
Hi Involute, you should be able to accomplish that by switching your units to mm before you do the export. Then either don't save that version or switch it back to continue your work.
I'll try to think about an option like you're asking about, it might be a little tricky since STL files don't have any setting in them for what unit system they are in and I don't want to make it sound like that isn't the case.
9224.3 In reply to 9224.2
Michael, perhaps he means something different.
I normally draw in "inches" and then output my STL files in MM. To convert the inch drawing, I "select all" and then scale by 25.4 to convert the solid to MM. I then save the STL and hit undo to return the scaling to the original inches setting.
Make sense?
Chris
9224.4 In reply to 9224.3
Hi Chris, yes I think I get it and I will see about putting in an option for units conversion for STL export.
Show messages: All  1  2-4
