Conformal Mapping to the Torus
 1-14  15-34  35-45
After 8 pages of algebra, I finally figured out how to code the two circles in the conformal map node.
The conformal formula shrinks the size of the torus down quite a bit.
Thanks to multiprocessing (I guess) there are actually 1,728 circles times 2, until I learn how to properly code the conformal mapping node.
(So Hide two and delete the rest of the circles.)
(Add two output nodes to the rRadius and RRadius outputs of the node.)
Some different colors would be nice. Silver works well for the circle sweep.
The NonConformal mapping to larger torus node is included, but r & R radii have not been added yet.
Like the WN.js nodes, the mapping nodes could be put in a similar extension to an extension .js file...
Rebuild of hex curves, with tolerance .001 is recommended.
I need to modify the FlatHexGrid to produce smaller hexagons, with the same center spacing. (As per speedy/AL.)
Sweeping the circles, FLOW to smaller torus, and trimming of the two tori surfaces by hex curves can likely be done with standard nodes.
So there is still more work to be done.
Edit: I do not know how to output only 2 circles, along with many hexagon sides, so may write a helper node to calculate the 2 circles.
EDITED: 28 Jan 2019 by BEMFARMER
9223.16 In reply to 9223.15
It seems like most nodes have only one output slot.
The few nodes with more than one output slot seem to have the same number of elements in each output?
The number of declared outputs must equal the number of outputs defined, or there is an error...?
9223.17 In reply to 9223.16
On second thought, I'll just incorporate the conformal map node into a macro. :-)
9223.18 In reply to 9223.17
Created Macro for conformal rCircle and RCircle.
Sweep node of the two circles works easily. About 12 seconds or so...
Placed the two nodes conformal and nonconformal mapping into a separate file, which can be copied to the nodeeditor/nodes/extensions folder.
Delete the transform2Mod files.
Added 90% to 100% scaling of individual hexagons. The number of columns and rows and planar domain remain the same size.
Added throughpoint curve, in addition to interpcurve "type". They are nearly identical, except at high magnification.
Added a Switch widget to switch between forming a full torus "grid", and a two column only grid, which is faster, and circle array-able.
(Did not add circles Macro for nonConformal node yet. Should be extremely easy...)
After forming the torus grid at 90%, do Rebuild and Join of hex sides.
Then do trim of torus by the grid. This takes over a minute or so.
For the previous nonconformal node assembly, replace the nonconformal node with a new copy.
Have not done a FLOW shrinkage yet...
9223.19 In reply to 9223.18
A couple of days ago the FLOW "shrinkage" worked.
Tonight FLOW is squashing and squeezing the hex "ribbon." :-(
Will make a fresh try tomorrow, or so.
9223.20 In reply to 9223.19
In an aha moment this morning: In order for FLOW to get the expected result of shrinking the pattern on the mapped torus, onto a torus of smaller r radius, and equal R radius,
it is necessary for the two tori to have the "seam" edge in equivalent locations. In this case the seams can both be in the center curve of the two donuts.
Otherwise the squish and stretch effect will occur as the inner hexes and outer hexes swap places.
(For special effects the seams could be located differently.)
9223.21
Hi Brian and Friends
An unconventional mapping on the Torus,
using your first Script ...
with some further precautions, I can get R1 and r,
and most importantly, the central point to the mapped hexagons
normal to the surface ..
This gives me the possibility to act on the basic hexagon for further transformations ....
I saw your new Script and it's Ok ...
it would be interesting if I could provide in output, the mapping of the Hex-normal face centers to the Torus Surface,
it would be a formidable tool for subsequent Transformations ... what do you think?
In any case, thanks for this last improvement-
As usual, the file is at this link:
http://www.mediafire.com/file/9au0nfcccmiog8z/CP_CMArrayHex.zip/file
Have a nice day to all
alberto
9223.22 In reply to 9223.16
Ehm -no. number of Outputs and Type, and also the number of elements are independent.
Each declared Output (addOutput) should also be defined (this.setOutputData) means - give it a value - that's the sense. The different outputdata are stored in an array for the different Outputs. The setOutputData method needs an index where to store the generated data in the array. If a method try to Access the Output Array of a node, the method should find data with the right types - I'm not sure, but I think Max places empty data with the right type to the Output Array by default while Output creation to avoid problems. At the end the Outputs are this Array.
Have a nice day
Karsten
9223.23 In reply to 9223.21
Hi AL2000,
The centers of the flat torus are available. Their conformal mapping should be the center of the mapped hexagons. (?)
To form vector, the start point is a corresponding point on the Rcircle, which is the center of the rcircle through the corresponding center point of the hexagon.
Each of such start point can also be calculated from u and v. (?).
This should be fairly easy to code in the .js. I'll try...
9223.24 In reply to 9223.22
Thank you Karsten.
Is there an example *.js node which outputs many objects, and only one, say a circle?
(My attempt to output one circle resulted in output of as many copies of the circle as there were objects output...)
9223.25 In reply to 9223.24
Hello Brian,
PatternSelArray, getCrvSFrame, ... gives independent different Outputs with different length.
it sounds that you tried it in a multiprocess function. Okay - could you post an example of the code? It is easier for me to figure out what happens on an code example.
Have a nice day
Karsten
9223.26 In reply to 9223.25
Hi Karsten,
Attached is a new .js node BADConformalMap, which will run in the node assemblage in about 12 seconds, but makes 100's of circles, instead of only 2.
The BadConformalMap.js can simply be copied to the nodeditor/node/extension folder.
The node assemblage is "ConformalMappingHexGridToTorus4BAD.
(Modifying the .js file requires that its former copy in the node assemblage be replaced with the modified version.)
I guess that a second multiProes needs to be added???
EDITED: 9 Dec 2020 by BEMFARMER
9223.27 In reply to 9223.26
Hello Brian,
it is a Problem with the using of the multiprocess function. It is in your case not necessary to us it. It's more useful to use it for multiple data with n x m permutations. The core System calls it - depending of the mode for each data object in the Input stream. You have to create dummies for the Output in it, because the core System try to evaluate an Array of results as Long as the defined Outputs.
I've made some changes to your file - please study it. At the end it would be better and faster to process your curves in a for-loop and not in a multiprocess function.
Have a nice day
Karsten
p.s.: Nevertheless -Congratulations! It Works:-)
EDITED: 31 Jan 2019 by KMRQUS
9223.28 In reply to 9223.27
Thank you Karsten.
I will study it.
Meanwhile, it was not very hard to turn the torus curved hex lines into a mesh with a square cross section, a solid, by using FLOW
to create the hex pattern on a slightly smaller torus with the same Rcircle. (The torus seams should match, i.e. both be on the same side of the tori.)
(The inner seam is made to match by creating the inner sweep circle by selecting the proper point, after selecting the circles center.)
(The seam of the circle can be checked by using the shortcut key for MarkCurveStart, on the circle.)
(It is helpful to have several different color styles in play.)
1. Create the surface pattern with hexes that have a small space between. This same space is used to form a smaller sweep circle of (r_radius-space), centered on R,
to make the smaller, inner torus.
2. Then for the outer edges, use the shortcut key v1.2 "select outer edges", (hide the 12 inner seam edges,) and join the hex sides to get hex curves.
3. Repeat for the inner edges.
4. For a pair of 12 adjoining hexagons, (which were two columns), perform 24 lofts between inner and outer edges. (24 manual lofts.)
5. Circular array these 24 hexagons, 12 copies around the torus.
6. Boolean Union the outer torus band, the 24 hexagon sides, and the inner torus band, to create the solid cage.
(A small circular Fillet did not work, after 20 minutes.)
EDITED: 31 Jan 2019 by BEMFARMER
Size: 128 KB, Downloaded: 51 times, Dimensions: 331x259px
Here is the simple algebra for calculating the two formulas for the "r" and "R" radii of the sweep and rail circles for the destination torus for the conformal
mapping to the torus. The formulas are incorporated in the conformalMapping node in mapping.js.
(see next post)
EDITED: 8 Feb 2019 by BEMFARMER
9223.30 In reply to 9223.29
Updated .pdf for algebra and trigonometry to calculate r, R, rcircle, Rcircle, "center"points of hexes, normals.
The nice png graphic of a .3dm, with alt codes for theta and phi helps to explain the math.
The map is subject to verification, and could have errors, or typo's?
The center points of the planar hexagons, after conformal mapping, are only "more or less" center points of the "hexoids" on the torus.
These points are now mapped in an update to the conformalMapT node.
Also, registration geometry such as a square and triangle can be Style selected, (I used color "coral"), concatenated with hexagons, and mapped to the torus.
The registration marks should be added by hand to quadrant I of the MoI screen, before the .nod file is opened.
Circles are not closed after mapping due to software error/incompleteness.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9066.6
Still need to code normals/lines through the center points.
I'll plan on posting the updated conformal node in a few days.
It was very difficult for me to get the points input and output slots coded correctly, with flu zombified brain, but Karstens corrections helped.
Is it possible to have TWO multiprocesses running in a node?
I plan to draw some "hobnail" geometry of the Fenton glass type, as a memorial. It appears to be partial spheres in a hexagon arrangement.
I'll have to measure the percentage of a sphere. It is in tapered spirals.
Also used gemarray to place cones on the surface of a torus. The density in the center became too high, and needs size reduction/scaling, or thinning:-)
A fairly unique ribbon?
From a conformal kagome torus mapping.
Size: 214.1 KB, Downloaded: 54 times, Dimensions: 455x458px
9223.32 In reply to 9223.31
very cool
9223.33 In reply to 9223.31
Looks Great! Chapeau!
What's next?
9223.34 In reply to 9223.31
Wow!
How can we do that?
Show messages:  1-14  15-34  35-45
