Blend Command V4
All  1-4  5-7
9222.5 In reply to 9222.4
Hi FED, do you mean this one here? :
To make that blend you'll need to delete the original circle curves, delete the end caps, then select the 2 edges and run the Construct > Blend command, here is an example video of the entire sequence:
Hope this helps!
9222.6 In reply to 9222.5
Hi Michael-
Thank you for your patience and help!!!!
Best,
FED
9222.7 In reply to 9222.6
You're welcome FED!
Show messages: All  1-4  5-7
