Blend Command V4
All  1-3  4-7
9222.4 In reply to 9222.3
Hi Michael-
I am sorry for asking another question, but I cannot seem to get the blend command to work on two cylinders at 90 degrees corners.
I tried the suggestions, but could you look? I have attached the file.
Again, I am new to modeling but truly enjoy MOI. MOI has really helped me to see design in a new way and learn about computer modeling. Truly lots of fun learning new techniques!!
best,
FED
9222.5 In reply to 9222.4
Hi FED, do you mean this one here? :
To make that blend you'll need to delete the original circle curves, delete the end caps, then select the 2 edges and run the Construct > Blend command, here is an example video of the entire sequence:
Hope this helps!
9222.6 In reply to 9222.5
Hi Michael-
Thank you for your patience and help!!!!
Best,
FED
9222.7 In reply to 9222.6
You're welcome FED!
Show messages: All  1-3  4-7
