How to clean up messy geometry from a file?
All  1-3  4-10
9208.4 In reply to 9208.3
Hi Chris, also instead of making 3 point arcs like I wrote above instead make 3 point circles since doing it by arcs means you have to decide on the start and end points.
Also what I wrote above about always picking 3 points like an equilateral triangle can be loosened a bit just try not to get the 3 points where they are very close to all being on a single straight line.
So make circles through 3 points like this and then trim them with each other:
9208.5 In reply to 9208.4
So I mean make circles like this:
Then Trim them all against each other and remove these areas:
9208.6 In reply to 9208.5
Then I think the ends match with circles and a little bit of lines here:
9208.7 In reply to 9208.1
Hi Chris, so this is what I got to (3DM attached also):
To finish it probably mirror that piece over then loft between pairs of edges and join those all up.
I'm not sure if it's accurate enough for what you need.
9208.8 In reply to 9208.1
And here is the result mirrored and lofted and joined. I have not checked how close it is to your original though.
9208.9 In reply to 9208.8
WOW! Thanks so much Michael. I had expected help as always, but this is above and beyond.
Best,
Chris
9208.10 In reply to 9208.9
You're welcome Chris, I hope I gave enough details so you can get an idea of how it was done.
Reverse engineering can tend to be pretty tricky, it often involves kind of decoding design intent.
Show messages: All  1-3  4-10
