Extrude with predefined length ?
All  1  2-5
9204.2 In reply to 9204.1
Hi Tom, so to extrude with a predefined distance you can set the following up on a shortcut key:
extrude distanceinput=10
But right now it's not possible to do that with an additional draft angle set though since the extrude command exits as soon as a distance value has been set. I'll see what I can do about that.
9204.3 In reply to 9204.2
Thank you Michael !
Don“t bother with it takes to much of your time, I had thougt it would be
just a short aditional line in the html file.
Just working on a series of endless objects with the same angle / length -
extrude parameters so it would be a little tiem saver to have a default
option ...
9204.4 In reply to 9204.3
Hi Tom, one thing that could help is to use this to automate pushing the tapered button and draft angle:
extrude tapered draftangle=20
Then you would only need to type in the distance.
Also don't need to do these one by one you can select a large number of closed curves and do them all in one go of the Extrude command.
9204.5 In reply to 9204.4
Very cool - thanks !
Show messages: All  1  2-5
