alternative navigation options
All  1-7  8-11
9199.8 In reply to 9199.7
Hi meanGoreng,
> once the zoom context has been entered. either moving the mouse position vertically or
> horizontally increases or decreases the zoom value ( put another way > positive and negative
> values being driven by either up/down OR left/right mouse position )
The part that is a little tricky is that it's virtually impossible to move the mouse only fully up/down or left/right. So for example when you move the mouse up and down there will be a little bit of left and right happening as well. So I need to know how that should behave.
I just tried in Cinema4D and Blender and there the mouse zoom seems to only do stuff in one direction, in Blender it's up/down only and in C4D it's left/right only.
9199.9 In reply to 9199.8
sorry michael. i wouldn't pretend to understand the actual math as such. just describing the behaviour. if you're interested ( and don't have access to maya or zbrush to test for yourself ) i could make a small vid of each to put a visual to it ( ? )
that said though. likely taken up too much of your time already. can't wait to give v4 a go with this one small tweak
9199.10 In reply to 9199.9
Hi meanGoreng, yes thanks that would be helpful if you could make a video of it. I don't happen to have Maya or ZBrush over here right now so I was hoping you might know of other apps than those 2 that behave in the way you like.
9199.11 In reply to 9199.10
will try get this done over the next few days. cheers michael
Show messages: All  1-7  8-11
