Old question
All  1-5  6-10
9185.6 In reply to 9185.5
Hi Michael, thankyou that is good to know. I would be happy if all letter holes would get their own style so they can be filled all at once in Affinity Designer for example. But I don't know if it is straightforward for you to detect text curves that are completely enclosed by another text curve.
-Martin
9185.7 In reply to 9185.6
Hi Martin, there isn't really any way currently in MoI to identify text curves. But it should be possible once there is an actual annotation text entity supported. So that will be the first step. It will probably take a few steps in annotation functionality before this can be implemented, until then I would recommend adding your text inside Affinity Designer instead of in MoI.
9185.8 In reply to 9185.7
I assumed that the text generated by the Dimension tool will be curve text and therefore made a script that styles letterholes so they can be filled in one step after PDF or AI export. The script can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9190.1
-Martin
9185.9 In reply to 9185.8
Hi Martin, probably the text generated by the Dimension tool will be it's own new kind of object, it won't just be regular curves.
9185.10 In reply to 9185.9
Thanks for the info Michael.
-Martin
Show messages: All  1-5  6-10
