Sweep between 2 curves - use only a portion of those curves
All  1-3  4-8
9175.4 In reply to 9175.3
My explanations were poor so I'm adding an example in GIF format:
Size: 4.3 MB, Downloaded: 77 times, Dimensions: 1280x720px
9175.5 In reply to 9175.1
Hi Fred, you should be able to control the length by using the Edit > Trim command to cut longer pieces to the length you want.
Or you might also try the Construct > Network command instead of sweep, it will internally trim off excess ends unlike sweep.
Sweep is set up to use the full length of the curve so you can do one rail sweeps like this with one profile at the center of the rail:
9175.6 In reply to 9175.5
I just discovered we can trigger the "Add trim point" with a shortcut in Edit > Trim = AWESOME
9175.7 In reply to 9175.6
Hi Fred, yes that's new in v4. You may have already seen it but it is mentioned in the Dec-11-2017 v4 release notes:
http://moi3d.com/wiki/V4Beta#Dec-11-2017
So with that you can set up a keyboard shortcut that also triggers different UI actions like pushing a button or changing a drop-down setting.
9175.8 In reply to 9175.7
Very cool . . .
Show messages: All  1-3  4-8
