Need help with Node Editor
All  1-4  5-10
9172.5 In reply to 9172.3
Hello Pixelhouse,
in 99% the Problem is a wrong shortcut "moi.ui.createDialog( 'nodeeditor/index.html'," has to point exactly to the folder e.g. C:\Program Files (x86)\moi3d\ui\nodeeditorv10rc3 so in this example:
moi.ui.createDialog( 'nodeeditorv10rc3/index.html', .......
it is also possible to install under your user-AppData for V4 - http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.767
Hope that helps - if not make some screenshots of your Folders!
Have a nice day
Karsten
9172.6
Thank you for the reply,
I´m currently out of the office and can´t check the path and folder. On monday I will check this.
Message 9172.7 deleted 14 Dec 2018 by WAYNEHILL5202
9172.8
Hi,Thanks for all the help!
The problem has been sovled. I put the nodeeditor folder direct under the Appdata\Roaming\Moi folder(not Moi\ui) that did the work.
Thanks everyone!
9172.9 In reply to 9172.8
Here the same :)
It's solved. I changed the name in the shortcuts.
Thanks @ALL
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
9172.10
Good news!
Then have fun with it.
Show messages: All  1-4  5-10
