Need help with Node Editor
All  1-2  3-10
9172.3
I have the same problem. Node editor is correct installed
and the command in the shortcuts is copied from a thread here.
moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
The nodeeditor folder is in the ui-folder and inside is the index.html.
I can't solve this issue and for me its's to abstract (copy this) to follow the instructions to install scripts or plugins.
I thik, it's to complicated to install plugins in moi for no programmers like me :D
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
9172.4 In reply to 9172.3
Can you zip up your ui folder and post the .zip file here so I can take a look at it?
Also check here for some troubleshooting information on the wiki:
http://moi3d.com/wiki/Troubleshooting
9172.5 In reply to 9172.3
Hello Pixelhouse,
in 99% the Problem is a wrong shortcut "moi.ui.createDialog( 'nodeeditor/index.html'," has to point exactly to the folder e.g. C:\Program Files (x86)\moi3d\ui\nodeeditorv10rc3 so in this example:
moi.ui.createDialog( 'nodeeditorv10rc3/index.html', .......
it is also possible to install under your user-AppData for V4 - http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.767
Hope that helps - if not make some screenshots of your Folders!
Have a nice day
Karsten
9172.6
Thank you for the reply,
I´m currently out of the office and can´t check the path and folder. On monday I will check this.
Message 9172.7 deleted 14 Dec 2018 by WAYNEHILL5202
9172.8
Hi,Thanks for all the help!
The problem has been sovled. I put the nodeeditor folder direct under the Appdata\Roaming\Moi folder(not Moi\ui) that did the work.
Thanks everyone!
9172.9 In reply to 9172.8
Here the same :)
It's solved. I changed the name in the shortcuts.
Thanks @ALL
9172.10
Good news!
Then have fun with it.
Show messages: All  1-2  3-10
