3d View - view pivot point
All  1  2-7
9165.2 In reply to 9165.1
Hi Fred, you can set it with the "Area" zoom tool on the viewport bottom toolbar. For that you first pick a center point and then area size and the center point you pick will become the new rotation pivot point.
9165.3 In reply to 9165.2
Perfect, I'll change my shortcut
Thanks for the quick reply
Fred
9165.4 In reply to 9165.3
You're welcome Fred! Also you can paste in the following script for the "command" part of a shortcut key, this one will do one point pick and set that as the 3D view's rotation pivot point:
script: /* Set 3D view rotation pivot */ var p = moi.ui.createPointPicker(); if ( p.waitForEvent() && p.event == 'finished' ) { moi.ui.mainWindow.viewpanel.getViewport('3D').targetpt = p.pt }
9165.5 In reply to 9165.4
Absolutely perfect, this is exactly what I was hoping for!
Thanks a lot
9165.6 In reply to 9165.5
One last question on that matter, is it possible to use the "mouse middle click" as the key for the shortcut?
9165.7 In reply to 9165.6
Hi Fred,
Sorry no, there isn't currently any way to run a script on a mouse middle click.
Show messages: All  1  2-7
