Hello! (and a noob workflow question)
All  1-9  10-11
9159.10 In reply to 9159.9
Hi Andreas,
> That allows sculpting nice damage detail but somehow destroys the smoothness of the original MoI export
> in curved areas (You can see at the upper right of the "issue" jpg). That is easily fixed by hand smoothing
> and it is worth the effort in my opinion. But I might just be missing something, I will have to go over the
> method again and play with settings
It could be that you're not getting vertex normals coming through but I also seem to remember that the ZBrush display mode by default likes to show polygons like that, maybe there is a display setting for that?
9159.11 In reply to 9159.10
Hi Michael!
You are absolutely correct, Zbrush occasionally displays a more faceted version of the model to improve performance during model rotation and does not do any smoothing between vertex normals according to what I have read.
The images I attached are renders in octane (with smoothing active in the material settings) and I suspect that this is an actual geometry issue due to Zremesher algorithm/settings I used. There are other settings with Zremesher that could potentially work to avoid this issue, but it has nothing to do with MoI's export which is perfect.
And please take everything I say with a grain of salt, I am new to the terminology and the programs and I do not want to appear like I understand more than I actually do. :)
Show messages: All  1-9  10-11
