v4 UI Customization
All  1-5  6-12
9157.6 In reply to 9157.5
Hi nate, your script is working fine for me over here. What version of MoI v4 are you using, is it the most recent one from http://moi3d.com/beta.htm ?
You'll need to be running a recent one (Aug-28-2018 or newer) for it to work, that's when this script interface for the scene browser was added.
9157.7 In reply to 9157.6
Hmm, ok good to know. Using the Oct-17-2018 beta here.
I'll noodle around w/it and see if I can make some progress.
If not it's a small matter ;)
Thanks–
9157.8 In reply to 9157.7
Hi nate, I double checked over here using Oct-17-2018 beta on Mac and your InitSceneBrowser.js file is working fine for me over here.
If you've been modifying things maybe you have the program guts of an older version or something like that?
If you use Help > About MoI, does that say you have Oct-17-2018 ?
9157.9 In reply to 9157.8
I downloaded a fresh copy of the beta and emptied the appdata folder to try and isolate the issue.
Of all things it seems to be setting the Browser position from "adjacent" to "opposite".
Last thing I would have expected, but one of the first things I tried.
Nate
9157.10 In reply to 9157.9
Hi nate, yup I can reproduce the error with browser position opposite. It looks like the scene browser is not quite initialized fully in that particular mode, at the time the startup script runs. I'll look into a fix.
9157.11 In reply to 9157.9
Hi Nate, so that bug where the scene browser is not ready to be accessed by a startup script when it's in "opposite" mode will be fixed in the next v4 beta. Thanks for reporting it!
9157.12 In reply to 9157.11
Excellent to hear. Thank you, Michael!
Show messages: All  1-5  6-12
