what is best solution for export .obj?
All  1-3  4-12
9151.4 In reply to 9151.2
phiro , i use ur export settings and i get little better.. nice quality and get less policount
9151.5
that not open new topic.. why i cant join that 2 parts
pic
https://imgur.com/a/KyiLXPz
see what i get when put texture
https://imgur.com/bN6no9P
3dm file
https://files.fm/down.php?cf&i=ygkpmefb&n=test.3dm
9151.6 In reply to 9151.5
There is a small gap which is narrow and tapering?
9151.7 In reply to 9151.5
Hi 4rw1n, yes as Brian writes the parts do not align well enough to be joined.
One side is closer than the other, there is a gap of 0.03 units on this area here which is too far apart to be joined or booleaned together:
9151.8
hii.. see now i try fix but dont know why now i cant connect that remove that line
https://files.fm/u/nzbgy2n3#sign_up
in moi is cant remove line but when i export in obj and put texture there no more
https://imgur.com/jt9GDC3
9151.9 In reply to 9151.8
Hi 4rw1n,
The line is an edge where 2 different surfaces are joined together, it's normal that objects made up of multiple surfaces joined together will have edges in them like that.
To remove it you would need to make a single larger surface instead of individual surfaces.
When you have 2 planes that meet there MoI is able to remove edges when those are boolean unioned together but not when you have 2 general surfaces touching like you have here.
9151.10 In reply to 9151.9
hi michael
why this happen
i make this
https://imgur.com/3WaeNXF
and connect it with network this look like this
https://imgur.com/MU33Yl1
and i mark all with ctrl + a and click on OFFSIET and click on SHELL, and i give thnickness and i put 0.07 direction is normal
when i export it .obj and open it in 3d coat see what happen inside is transparent, how to fix it.
https://imgur.com/u77Id7X outside
https://imgur.com/X3fZfEl inside
here is 3dm file
https://files.fm/u/xzmfe54s
9151.11 In reply to 9151.10
Hi 4rw1n, unfortunately the Shell function in the geometry library that MoI uses does not work well with a case like this with multiple surfaces meeting at different angles. For thickening an open surface it will only work on a single surface or with multiple surfaces that are smooth to each other or meet at a 90 degree angle.
For thickening something like you have here it makes messed up results in corner areas.
So I'm sorry Shell just won't work for your case, you need to use some other method for constructing it.
9151.12 In reply to 9151.10
Hi 4rw1n, also on something like that it can work better to make a solid and then shell the solid rather than trying to thicken an open surface. With a solid shell the shelling mechanism gets to intersect extended surfaces with "side walls" which tends to work better. When you thicken an open surface it's a pretty different process which has more difficulties with surfaces all at different angles to each other.
I've attached a result of making your object into a solid and then shelling it. There was still an error in one spot where you had a thin pointy piece which I had to fix up manually.
Also I made all the main pieces using Construct > Planar rather than Network, that should also help with offsetting and shelling work since it will make trimmed analytic plane surfaces rather than general surfaces.
Show messages: All  1-3  4-12
