Need help with brain teaser
All  1  2-10
9142.2 In reply to 9142.1
Hi Chris, usually stuff similar to that is better done by texture mapping in a rendering program. Or also there are some sculpting programs like ZBrush or 3D Coat which are heavily focused on applying displacement.
One thing that you could try with MoI though would be to make a bitmap image with your pattern in it and use ZSurf (see http://moi3d.com/forum/index.php?webtag=MOI&msg=602.7) or Max's HeightMap script (http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.1 and the script can be found at Max's file archive here: http://moi.maxsm.net/media/files/ ) to make a textured surface and then use Transform > Deform > Flow to apply it onto your target surface.
9142.3 In reply to 9142.2
Thanks Michael. I should have mentioned the end result will be 3D printed on my SLA machine, so there has to be an actual displacement of the surface.
Chris
9142.4 In reply to 9142.3
Hi Chris, the ZBrush and 3D Coat programs should be able to apply displacement and give you displaced geometry in the form of polygons which could then exported to STL format for 3D printing.
The other methods I mentioned, ZSurf or Max's HeightMap plug-in will also generate geometry that can be exported as well.
Free Blender made also some displacements! ;)
And if you want your bricks as the Moi flow command, you have inside free Sketchup 2017 Make, 2 plugins that make that : Flowify and Shape Bender :)
9142.6
Hello,
Project, Sweep, Boolean and Fillet should be able to do this.
9142.7 In reply to 9142.1
Hi Chris, maybe it would help if you could show an example of what type of result you're trying to get. Is it something that's kind of like a bumpy texture or do you want something more like crisp sharply defined bricks like little boxes?
I tested a method.
First you use your wall and apply the FatLines plugin.
Use it with your wall in the good view (good view depends to the perpendicular you use... test each or rotate your wall to be horizontal
With your file I use 0.015 inch large
delete or hide your original curves
With new curves, extrude them
You have now a solid to flow on your wall.
Flow it using a plan adapted (cf my picture where plan is in green)
To finish your wall, do a boolean difference between wall and 3D bricks border
Adapt this method with right adjustements in size of borders, in depth, in source plan of flow...
Beware about faisability... I don't know if printer could do so tiny details...
All done in MOI3D with a single plugin (Fatlines Thanks to Max)
EDITED: 20 Feb 2021 by PHIRO
Size: 791.4 KB, Downloaded: 60 times, Dimensions: 1632x1022px
Size: 822 KB, Downloaded: 30 times, Dimensions: 1632x1022px
Size: 952.1 KB, Downloaded: 35 times, Dimensions: 1632x1022px
Size: 687.7 KB, Downloaded: 27 times, Dimensions: 1632x1022px
Size: 590.9 KB, Downloaded: 26 times, Dimensions: 1632x1022px
Size: 486.6 KB, Downloaded: 24 times, Dimensions: 1632x1022px
Size: 534.3 KB, Downloaded: 21 times, Dimensions: 1632x1022px
Size: 332.6 KB, Downloaded: 21 times, Dimensions: 1632x1022px
Size: 359.8 KB, Downloaded: 36 times, Dimensions: 1632x1022px
9142.9 In reply to 9142.8
Pretty close. I'm only just now getting back to this problem. I will try this method with some minor changes to suit the prototype, which are bricks in a foundation.
Thanks!
Chris
9142.10 In reply to 9142.9
Like Phiro, FatLines to extrude was my first thought as well!
Show messages: All  1  2-10
