UI Icons.
All  1-3  4-16
9138.4 In reply to 9138.1
It's beautiful.
9138.5
Very nice vector work \m/
9138.6 In reply to 9138.5
Great icons. Going to install now to Custom UI. Much appreciated!
9138.7
Really nice work.
I started redrawing the icons myself last year, but never managed to finish all of them.
http://moi3d.com/forum/index.php?webtag=MOI
Now I don't have to :)
9138.8
Really smart designs, van. Lots of inspiration for creative minds here.
-- Cody
Dark Gray Theme (Compatible with MoI 3.0 and MoI 4.0 Beta)
9138.9
I have a few icons that have remained black. In particular lighting which is part of the icons that you created
EDITED: 28 Sep 2021 by ZOOEN
9138.10 In reply to 9138.9
It's particular icons for Blender Input Ouput!
9138.11 In reply to 9138.9
Hi Zooen,
Focus on where, and how, the customui icons are stored.
Using CustomUI-modified.zip, the Path to the customUI files to substitute should be at %AppData%>Roaming>Moi>Startup. (???)
(I have not changed mine.)
EDITED: 16 Feb 2021 by BEMFARMER
9138.12 In reply to 9138.9
I think the icons for Max's CustomUI mod are stored as embedded base64 data inside each .js file.
So you would need to edit the script files, you can find them in the moi appdata startup folder, and change the line that says:
var icon = "data:image/png;base64,iVBORw0KGgoAAAANSUhEUg <...large amount of base64 data ...>
to instead say:
var icon = "icons/LightingPresets.png";
And then that will make the button's icon come from that PNG file in the ui\icons folder.
9138.13 In reply to 9138.12
Many thanks Michael,
on the first try, var icon = "icons / LightingPresets.png"; did not work. then I managed to get my old neurons working. Obviously it came from the name of the file!
var icon = "icons / Lighting.png"; works
Five icons remain black, it does not exist in the Van list
(excuse me, this is google translation from French)
In notepad++, from the customui 88 SubdivTtools js file, I was able to cut out the base64 code, ( All of the code from just after ...base64, on down to just before " command="_Subdiv_beta9" ,
and paste it to the onle site:
https://codebeautify.org/base64-to-image-converter
and then download a jpg image.
I suppose an icon editor program could then make an icon,
but I do not know much about all of this.
What is a good, free, icon creator program?
Size: 4 KB, Downloaded: 38 times, Dimensions: 64x64px
9138.15 In reply to 9138.14
Why not use Moi itself ?...
At the end use the Print Screen Key and past in any 2D prog for have your image to manage ! :)
In the free Fotosketcher for example! (by a talentuous French guy) ;)
https://fotosketcher.com
(you can resize your image in 64 * 64 pixels if you want...and some other cool things!
here the process (all take 10 seconds! ;)
Past your save Screen from the ClipBoard
Crop / reframe
Permute image
Apply an effect if necessary
Resize image 64*64
Save you image 64*64
et voila :)
here just for validate the process
Here the image.jpg from fotosketcher
you can now apply your Base 64 beautity...
so the icon will be maybe something like that or smaller/bigger following the Options/ UI size of Moi...
EDITED: 17 Feb 2021 by PILOU
9138.16
Thanks Brian and Pilou. I will study all this carefully, it is very interesting to customize and standardize its interface in a pleasant way.
-Zooen
Show messages: All  1-3  4-16
