Save custom UI?
All  1-7  8-11
9121.8 In reply to 9121.5
Hi mat, for the LightingOptions one it seems that it is expecting to have a listing of different lighting modes saved in the moi.ini file already, I guess it would get populated by using the older lighting options dialog script. Or maybe from the old CustomUI in v3 maybe, something like that.
Maybe if you can run one of those older versions it can get the settings populated in your moi.ini file so that menu could work in v4.
9121.9 In reply to 9121.7
Ah, now it works! Scripts, Obj library and Lighting options are all visible now....but somehow the script names are coming from V3 (not functional)...since I haven't yet installed all my V3 scripts into the V4 commands folder...? I noticed V4 also has my V3 hotkey set up...automatically.
Next...is to separate out the "Draw Curve/Draw Solid" and "Construct/Transform" panel windows. Is it the same process in V4 as in V3?
Thanks Michael!
9121.10 In reply to 9121.6
You were right Brian to move the "customui" up one level. Works now.
The "LightingOptions.htm" I had put into the commands folder from a script. Thought I needed it for the "Lighting" button. Seems to work with and without it...not sure if it's linked to my V3 somehow...or built into V4.
Thx!
9121.11 In reply to 9121.9
Hi mat,
Yes, you'll need to copy over any additional scripts that you added into the V3 commands folder.
But for v4 instead of copying them into the app's commands folder you can put them in the appdata command folder (/Users/<username>/Library/Application Support/Moi/commands) and the benefit to that is that new versions will find them in that centralized location and so you won't have to copy them around again after that.
Yup, you can use the same process for that, or also a newer method for v4 is you can put in a startup script (in the appdata/Startup folder) to do it, get it from:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.8
Show messages: All  1-7  8-11
