show mesh on model
All  1-3  4-5
9112.4 In reply to 9112.1
Hi Mr. Yuri, I'd probably recommend exporting to .obj format which will generate a mesh. Then you can bring that mesh back into MoI as a set of line segments using the converter here: http://moi3d.com/resources#Obj23dmWireframe_converter . Or you can also bring it in as surfaces using Max's script from http://moi.maxsm.net/media/files/ , find the ImportObj one.
If you want to generate a 2D DXF file with hidden lines removed like the one you show seems to be, use Max's one for that.
The Wireframe mode that you mention above is a viewport display thing, it would not have any effect on DXF output.
9112.5
Thanks Brian, I learned something new about scripts.
And thanks Michael.
Seems it's working fine by using Max scripts.
Awesome somebody took the time to make all the extensions for the community.
Show messages: All  1-3  4-5
