show mesh on model
9112.1
Hi all Gurus :)
I wonder if it's possible to show/project grid mesh on model so I can output the 3D view picture as DXF and use it on CNC.
Want to make depth illusion DXF picture so I can engrave it.
Something like on the picture attached.
Is there a way, or plugin available in MoI?
EDITED: 27 Oct 2018 by MR_JURAJ
Size: 189.5 KB, Downloaded: 48 times, Dimensions: 283x245px
9112.2 In reply to 9112.1
Wireframe mode seems like thing I want but the script made by Max seems like it's not there anymore.
http://moi.maxsm.net/item/12
9112.3 In reply to 9112.2
It is an inline script, so press Tab in MoI and enter the text in command box,
Or set up a shortcut key, such as Alt+W for example.
9112.4 In reply to 9112.1
Hi Mr. Yuri, I'd probably recommend exporting to .obj format which will generate a mesh. Then you can bring that mesh back into MoI as a set of line segments using the converter here: http://moi3d.com/resources#Obj23dmWireframe_converter . Or you can also bring it in as surfaces using Max's script from http://moi.maxsm.net/media/files/ , find the ImportObj one.
If you want to generate a 2D DXF file with hidden lines removed like the one you show seems to be, use Max's one for that.
The Wireframe mode that you mention above is a viewport display thing, it would not have any effect on DXF output.
9112.5
Thanks Brian, I learned something new about scripts.
And thanks Michael.
Seems it's working fine by using Max scripts.
Awesome somebody took the time to make all the extensions for the community.
