Tube Intersection
All  1-6  7-16
9108.7 In reply to 9108.6
Hi Sharif, is the attached model what you're trying to get? I found a little easier method using booleans instead of trim.
What I did to start with was make this tube all filled to start with, no wall thickness yet:
Now boolean union those 2 solids and that has the outer skin how it should be. You can now clear the inside of one direction by selecting the combined solid and using boolean difference with the inner curve as the cutting object.
To clear the inside in the other direction, extrude out the inner curve here a ways past the juncture and use that extrusion as the cutting object in boolean difference:
9108.8 In reply to 9108.6
Hi Sharif, probably the easiest method is to do that outside first for both pieces.
I mean generate 2 non-hollow pieces and boolean union those first:
That gets the outside formed. Now to clear out the insides, in one direction that can be done by boolean difference with this inner curve:
And to clear out the other direction, make a mitered one-rail sweep of this inner curve and use that object as the cutting object in boolean difference:
9108.9 In reply to 9108.8
Hi Michael;
Thank you for your help!. Per your instruction: step 1, I created the outer solid for both pieces and union them. Step 2, I did the same for the inner solid. Step 3, I use the Boolean differences and I subtracted inner solid from outer solid and it worked (See Attached Image)
-sharif
Size: 193.1 KB, Downloaded: 24 times, Dimensions: 1400x865px
Size: 122 KB, Downloaded: 30 times, Dimensions: 895x689px
A simple 3 big extrude
Then 2 Boolean Merge, then Boolean Union don't make the trick ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/tubeintersection_pilou.3dm
EDITED: 27 Oct 2018 by PILOU
9108.11 In reply to 9108.10
Nope, not quite - your version does not have all the interiors fully cleared:
9108.12 In reply to 9108.11
I have sent the file before the last boolean merging! :)
Select All / Bollean Merge and you will have your result! :)
(of course on killing the parts merged resultant! )
My Moi French Site My Gallery
9108.13 In reply to 9108.12
That doesn't work for me, did you mean to post a different file?
9108.14 In reply to 9108.13
Sorry for for the delay! New process! :)
(from the original post 1)Select only the 3 internal or external sections
- Big Extrude them one by one with closed faces enabled
- Boolean Merge the upper one (and kill the part not wanted)
- Kill the 3 curves sections
- Boolean Union All
- Kill closed 3 faces sections
- Select all then Shell (internal or external : Normal/ Flip following first choice at the beginning)
Seems fine! :)
Pinky is original
Gold is mine! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/tubeintersection_pilou2.3dm
EDITED: 29 Oct 2018 by PILOU
9108.15 In reply to 9108.14
Hi Pilou, yup I can follow your latest steps. But the Shell function isn't very reliable for thickening surfaces with sharp corners so it can be good to have a different way to do it.
9108.16 In reply to 9108.15
All the roads go to Roma! ;) (or almost :)
Show messages: All  1-6  7-16
