Tube Intersection
All
1-9
10-16
Frenchy Pilou (PILOU)
27 Oct 2018 (10 of 16)
9108.10
A simple 3 big extrude
Then 2 Boolean Merge, then Boolean Union don't make the trick ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/tubeintersection_pilou.3dm
EDITED: 27 Oct 2018 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
27 Oct 2018 (11 of 16)
9108.11
In reply to
9108.10
Nope, not quite - your version does not have all the interiors fully cleared:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
27 Oct 2018 (12 of 16)
9108.12
In reply to
9108.11
I have sent the file before the last boolean merging! :)
Select All / Bollean Merge and you will have your result! :)
(of course on killing the parts merged resultant! )
My Moi French Site
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
27 Oct 2018 (13 of 16)
9108.13
In reply to
9108.12
That doesn't work for me, did you mean to post a different file?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
28 Oct 2018 (14 of 16)
9108.14
In reply to
9108.13
Sorry for for the delay! New process! :)
(from the original post 1)Select only the 3 internal or external sections
- Big Extrude them one by one with closed faces enabled
- Boolean Merge the upper one (and kill the part not wanted)
- Kill the 3 curves sections
- Boolean Union All
- Kill closed 3 faces sections
- Select all then Shell (internal or external : Normal/ Flip following first choice at the beginning)
Seems fine! :)
Pinky is original
Gold is mine! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/tubeintersection_pilou2.3dm
EDITED: 29 Oct 2018 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
29 Oct 2018 (15 of 16)
9108.15
In reply to
9108.14
Hi Pilou, yup I can follow your latest steps. But the Shell function isn't very reliable for thickening surfaces with sharp corners so it can be good to have a different way to do it.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
29 Oct 2018 (16 of 16)
9108.16
In reply to
9108.15
All the roads go to Roma! ;) (or almost :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-9
10-16
