Saving multiple ?
All  1-8  9-13
Bravo! Works like a charm for the named objects selected to .OBJ format! And unamed! :)
And what about if the same will be with .3Dm files format ?
9105.10 In reply to 9105.9
Hi Pilou, for saving to .3dm format go to line #42 where it is appending the .obj file extension:
        var filename = g_dirname + name + '.obj';
And change it to append a .3dm file extension instead:
        var filename = g_dirname + name + '.3dm';
Excellent!
Ps Must I do relaunch Moi when I edit and save the js file ?
9105.12 In reply to 9105.11
Yes, unless you have set DisableFileCaching=y as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6727.2
9105.13 In reply to 9105.12
Many thanks : all is clear after this ultima trick! :)
All that for 2 things! :)
1- Can make multiple Drag & Drop multiple of objects separated inside the marvelous free render of MagicaVoxel! :)
2 - Have a best precision in the crazzy MagicaVoxel who accepts by Drag & Drop objects OBJ but only in a maxi matrix 126 * 126 *126 !
So a drastic reduction of the original object!
So we must make some tricky spliting objects :) http://moi3d.com/forum/index.php?webtag=MOI&msg=9096.2
In theory we can have 16*16*16 so 4096 matrix of 126 *126 *126 (something like 8 billions of cubes) so a little more precision! :)
more the object is big more the precision increase! (if all parts are put in several matrix! :)
In theory we can have 16*16*16 so 4096 matrix of 126 *126 *126 so a little more precision! :)
Here 2 Moi objects destroyed (Cylinder + Half Sphere) & a Cone with a very low resolution in a little matrix 34 * 52 * 39 !
Exactly the same object from another point of view and a fisheyes effect of 220° !
EDITED: 21 Oct 2018 by PILOU
Show messages: All  1-8  9-13
