Saving multiple ?
All  1-7  8-13
9105.8 In reply to 9105.7
Hi Pilou, yes that script ignores objects without any name assigned.
You could change this pretty easily though, for example if you want unnamed objects to go to a file unnamed.obj try modifying line 26 of the script. Currently it has:
	if ( name == '' )
		continue;
Try changing it to:
	if ( name == '' )
		name = 'unnamed';
Bravo! Works like a charm for the named objects selected to .OBJ format! And unamed! :)
And what about if the same will be with .3Dm files format ?
9105.10 In reply to 9105.9
Hi Pilou, for saving to .3dm format go to line #42 where it is appending the .obj file extension:
        var filename = g_dirname + name + '.obj';
And change it to append a .3dm file extension instead:
        var filename = g_dirname + name + '.3dm';
Excellent!
Ps Must I do relaunch Moi when I edit and save the js file ?
9105.12 In reply to 9105.11
Yes, unless you have set DisableFileCaching=y as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6727.2
9105.13 In reply to 9105.12
Many thanks : all is clear after this ultima trick! :)
All that for 2 things! :)
1- Can make multiple Drag & Drop multiple of objects separated inside the marvelous free render of MagicaVoxel! :)
2 - Have a best precision in the crazzy MagicaVoxel who accepts by Drag & Drop objects OBJ but only in a maxi matrix 126 * 126 *126 !
So a drastic reduction of the original object!
So we must make some tricky spliting objects :) http://moi3d.com/forum/index.php?webtag=MOI&msg=9096.2
In theory we can have 16*16*16 so 4096 matrix of 126 *126 *126 (something like 8 billions of cubes) so a little more precision! :)
more the object is big more the precision increase! (if all parts are put in several matrix! :)
In theory we can have 16*16*16 so 4096 matrix of 126 *126 *126 so a little more precision! :)
Here 2 Moi objects destroyed (Cylinder + Half Sphere) & a Cone with a very low resolution in a little matrix 34 * 52 * 39 !
Exactly the same object from another point of view and a fisheyes effect of 220° !
EDITED: 21 Oct 2018 by PILOU
Show messages: All  1-7  8-13
