Moi as vector graphics program
All  1-3  4-8
9103.4 In reply to 9103.2
Thanks for the prompt reply. I use PDF export however with JPG or PNG (for transparency) export and line weight I could avoid DrawPlus.
I think that's all what I need to create small icons. The feature with DPI export would be useful to keep the scale of the exported drawings.
9103.5 In reply to 9103.4
Hi andras, I do want to add more types of 2D vector type functionality in MoI but it will be a kind of gradual process over time. For now you would need to use MoI in combination with a 2D vector program for controlling things like line weights.
The main focus currently is more on modeling 3D forms and then you can generate a hidden line drawing and bring it in to your 2D vector program to do more stuff there.
Message 9103.6 deleted 20 Oct 2018 by ANDRAS2
9103.7 In reply to 9103.5
Line weight probably not necessary because I could use offset. I would find only PNG export useful with DPI settings.
9103.8 In reply to 9103.7
You can use directly Flat Lines by Max Smirnov for your curves inside MOi ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
My Moi French Site My Gallery
Show messages: All  1-3  4-8
