V4 beta Oct-17-2018 available now - SubD to NURBS conversion
 1-20  21-40  41-60  61-80  81-100  …  261-264
Hi Michael and all,
cool that the SubD to NURBS converter handles also Ngons
nicely. :-)
Bildschirmfoto-2018-10-19-um-08-19-58
EDITED: 19 Oct 2018 by STEFAN
9100.42
Yes! It works!
Thanks for healing my NURBS constipation, Michael!
Also there are a couple of cases where the converter will only be able to do G1 continuity instead of G2.
That will happen in some cases at the boundaries of open meshes and also at vertices of greater than valence = 8 (more than 8 edges coming off of a single vertex).
But these are not good things to have for sub-d meshes anyway so I don't think they are likely to run into very often.
9100.44 In reply to 9100.42
Hi Metin, ha look at that high quality poop conversion! :)
9100.45
:D
The only thing I really miss is the option to convert high-polygon meshes to NURBS.
I loaded the attached old voodoo doll of mine (once created for a quick cartoon), and I forgot that the pins are high-poly.
It took quite a while to load, and MoI still tried to subdivide the high-poly pins, resulting in patch tearing and exported polygon tearing, while it'd be great if high-poly objects would be recognized as high-poly (maybe with a user-defined treshold) and converted to as few NURBS patches as possible.
Metin
9100.46 In reply to 9100.45
Hi Metin, yeah so those pins were not meant to be have sub-d smoothing on them, right?
I'm not really sure how feasible it would be to try and detect that automatically - for this converter you would want to leave those out of the .obj file and not try to bring them in with the body.
The tearing I think is a bug in MoI's handling of faces that are pretty small, not actually in the conversion part. If you scale those up by say 100 times in size before bringing them in you might see them go away. It can happen in other places in MoI too, it's just more noticeable in the converter since it can generate little tiny faces more than other things you usually do in MoI. I'm still working on tracking down this tiny face mangling bug, it crept in sometime after MoI v3.
9100.47 In reply to 9100.45
Also I'm hoping to get the converter to have a progress bar and a cancel button too.
9100.48
Sounds good. Good luck hunting those darn bugs.
I tried a little more complex, but completely manifold, subdivision-ready OBJ file, and it becomes a joined surface after importing in MoI using the new Sud-D function.
I've attached the OBJ file. If you select and delete the main part of the result, some separate edges remain.
Regards,
Metin
EDITED: 19 Oct 2018 by METIN_SEVEN
<< Also if you want to set up a shortcut key for the SubD to NURBS converter use ImportSubD for the command name. And if you want to run it in a script you can use moi.geometryDatabase.fileImportSubD( 'filename' );
and the very practical
Press TAB then write ImportSUBD or importsubD or ImPorTSubD or anything you want but without space! ;)
the ZBrush dog
and here a model 30 000 polys (Zbrush)
By Félix Barc
EDITED: 19 Oct 2018 by PILOU
9100.50
Thanks Michael!
Size: 199.6 KB, Downloaded: 85 times, Dimensions: 511x461px
9100.51 In reply to 9100.48
Hi Metin,
That's the same "very small faces getting mangled" problem that I was talking about earlier. For now if you have an object that's only about 1 unit across it will run into some problems, scale objects like that up by say 100 times before you do the import.
I've attached the result of scaling your object up by 100 times and this version should now have all joined edges when you import it.
9100.52 In reply to 9100.51
You're right, the upscaled OBJ file becomes a solid after import. I can use that as a workaround until it's fixed.
Metin
My Moi French Site My Gallery
9100.54 In reply to 9100.53
Thanks Michael for this great feature !
9100.55 In reply to 9100.1
I do not know how to comment on this new SubD-in Nurbs .. excellent you are the best ..
Maybe when you have time it would be useful to be able to determine in the models imported before conversion which edges should be creased. a bit like it works with FreeShip. here is an old example below. this would allow you to create surfaces with sharp edges like a cube or something..
The ship is converted with edges creased and has a nice sharped nurbs surfaces..
Here the link to sources of Freeship..
https://github.com/markmal/freeship-plus-in-lazarus/releases
EDITED: 19 Oct 2018 by PAFURIJAZ
Size: 469 KB, Downloaded: 121 times, Dimensions: 1365x743px
Size: 100.8 KB, Downloaded: 99 times, Dimensions: 1366x744px
9100.56
And here a file generated with FreeShip from SubD with sharp edges.
EDITED: 4 Nov 2021 by PAFURIJAZ
9100.57
Talking about crease, Modo CC crease + mesh freeze works pretty well ! (but it's not sharp crease off course)
EDITED: 23 Mar 2019 by PAQ
9100.58
Hi, the new SubD is realy good at modeling cushions. My workflow is modeling in Moi3D, export a sketchup, export obj from sketchup,
and SubD in Moi3D. When i export obj from Moi3D, SubD is not working as expected, whatever kind of obj export. Why that?
Moujiik
Size: 87.3 KB, Downloaded: 146 times, Dimensions: 1325x913px
9100.59 In reply to 9100.58
Hi Moujiik, when you export from MoI you should set the option for "Weld vertices along edges" in the expanded dialog options.
9100.60 In reply to 9100.59
Thank you, the result is just perfect. I was wondering why we don't have the alternative to directely apply SubD to the model,
then i thought it's probably better to ajust some parameters of the obj file? Anyway that's a great tool. Genius!
Size: 27.1 KB, Downloaded: 97 times, Dimensions: 705x551px
Show messages:  1-20  21-40  41-60  61-80  81-100  101-120  …  261-264
