V4 beta Oct-17-2018 available now - SubD to NURBS conversion
 1-19  …  220-239  240-259  260-264
9100.260 In reply to 9100.258
The two ends of the tubes have triangles, and T vertices.
By importObj script, and splitting the ends triangles, and saving, the tube will subD, but the ends are still polygons...
9100.261
@Pilou
I dont understand, why you see 2 Million Polys? But thanx, I will try out other pivot-settings.
@bemfarmer
thank you too - so I will take look to this too
I'm happy now .. it was my fail - did overwork the tube-ends. Now ist fine ...
https://i.imgur.com/ByHQ19d.jpg
EDITED: 26 Feb 2019 by LORDFOX
9100.262 In reply to 9100.261
When you import it by SUbD inside Moi
then export it as obj you have a choice to 67 000 (mini) to 2 000 000 polys (maxi) ;)
9100.263 In reply to 9100.258
Hi Lordfox,
> But one Polygon-Object I cant load with the SubD Tool. I dont know why, its very simple, no holes,
> only quads (754 Vertices) ... hmmm I dont know .... created in Silo 2.5.5.
It's because there are errors in the mesh structure, some degenerate faces and some faces with inconsistent normal directions.
The Rhino check command says:
quote:
This is a bad mesh.
Here is what is wrong with this mesh:
Mesh has 4 degenerate faces.
Important things to consider with this mesh:
Mesh has 128 faces with directions different from the mesh as a whole. Although this does not
necessarily mean that the mesh is bad, it can cause problems if you're doing mesh boolean operations with it.
Mesh has 4 pairs of faces that intersect each other. Although this does not
You may be able to fix it by using the "unify normals" tool in Silo:
https://nevercenter.com/silo3d/wiki/index.php?title=Unify_Normals
In the next v4 beta which should be released just later today, the sub-d conversion will skip over the problematic faces and give this result:
9100.264
Thanx ;) - so its a problem of silo, wrong faced polygons in silo sometimes black and I see it and I fix it, but in somtimes my silo-object looks clean and the wrong polygon(s) are not "black" in silo.
I will set a wacom key, that makes all faces unify and after this a save.
Show messages:  1-19  …  200-219  220-239  240-259  260-264
