V4 beta Oct-17-2018 available now - SubD to NURBS conversion
 1-17  …  198-217  218-237  238-257  258-264
9100.238 In reply to 9100.237
>In the future I want to add a new type of object into MoI for representing a sub-d control cage. Then the sub-d importer would make that type of object and you would be able to access the sub-d control cage points in MoI rather than only the converted NURBS object as it is now.
Wow... That would bring the game to a whole other level. I am already all over the subD coversion of the beta, but being able to control the result on the fly... I am very excited! But first things first!
9100.239 In reply to 9100.238
Hi nameless, yes really the primary thing I want to have for SubD is the ability to make fairly sparse sub-d cages directly in MoI. They would be particularly good for semi-organic things like vehicles.
But in order to have that the conversion from SubD to NURBS needs to make high quality results and the OBJ importer was the easiest way to get that part worked out initially.
9100.240
that sounds like the dream, really.
2 thoughts from my short experience with the program so far:
- Understanding Clines is so very crucial to designing in MoI (and I am still not 100% there). The Clines lock script is also so handy that in my eyes it would justify it being visible somewhere in the interface. I
currently draw Clines by "faking" a line tool and then canceling. Is there a more straightforward way? Would a Cline construction mode button make sense?
- Is there a way to adjust the scale of an object being pasted during the axises adjusting face? (After you Ctrl+Shift+V it on an object's surface). I tried looking it up in the documentation but I couldn't find it. If
not, wouldn't it be very useful to be able to scale the object around its center projected on the snapping surface?
I was very hesitant to suggest these, as 1) I am quite new and I might be wishing for features that already exist due to ignorance and 2) I totally get the advantages of a very simple interface on first program launch vs an intimidating full featured UI. So I am just pointing these out just for the sake of feedback through the eyes of a new user!
EDITED: 5 Feb 2019 by NAMELESS
9100.241
is it possible to increase the size of the colour palette.
I know there are more options in the V4 beta palette but the basic colour panels
are very small compared to V3.
Barry
9100.242 In reply to 9100.240
Hi nameless,
> I currently draw Clines by "faking" a line tool and then canceling. Is there a more
You could set up one of the Cline plug-in commands from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.25
I do want to add an official persistent cline command in the future, I haven't figured out the details of how they should be selected yet though.
> I couldn't find it. If not, wouldn't it be very useful to be able to scale the object around its center
There is not currently any way to do this directly inside the PastePart or Orient commands but I do think it would be a good thing to add.
9100.243 In reply to 9100.241
Hi Barry,
Which colour palette are you asking about, do you mean the Scene browser > Styles section? Or the one that pops out from the properties panel?
9100.244 In reply to 9100.243
it’s the pop up properties panel.
Barry
9100.245 In reply to 9100.244
Hi Barry, can you show me what yours looks like?
Over here my v4 looks like this:
And my V3 one looks like this:
9100.246 In reply to 9100.245
this one.
Barry
9100.247 In reply to 9100.246
ahoy,
v4(right one) seems actually bigger/larger than v3..at least on my screen..windows 10
EDITED: 6 Feb 2019 by MARCO
9100.248 In reply to 9100.246
Hi Barry, hmm well that dialog is actually displayed by a Windows operating system call, it's a little different than other dialogs in MoI.
MoI v3 did make a custom template for the dialog that re-arranged things a bit like moving the custom colors off screen, I guess I also made the color squares slightly larger. MoI v4 just uses the default one given by Windows.
I guess it might be possible for me to have an option to use the same one as v3 did, I'll see about that.
9100.249 In reply to 9100.247
Hi Marco,
this is mine on Surface Pro 4.
Barry
9100.250 In reply to 9100.249
ah i see. well, you've got a 3k device there, which might generate some scaling issues in win 10. i dunno if michael can adress this within the system call.
9100.251
Hi, I'm a new Mo-I user so please excuse me if this feature suggestion is covered in a plugin/script.
The idea is to add more snapping options in line curve drawing mode, which are sensitive to their nearby points.
For example:
-- so as the cursor adds a new point, Moi3d suggests an alignment point with similar vertical placement, drawing a dashed line like the one I've drawn in magenta. It could detect any kind of angled line extensions, as with the cyan dashed line.
I've used other programs with similar functionality; it is super helpful for fast construction. I realise you can do this by manually adding construction lines as in traditional tech drawing -- this is a faster alternative.
Cheers.
PS absolutely loving the interface design and functionality of this program. Great work Michael!
9100.252 In reply to 9100.251
Hi Tover, I'm glad you are liking MoI!
So the construction lines function is what MoI has for that kind of functionality. And just to make sure - that doesn't just mean drawing additional regular lines, you can create what MoI calls a "construction line" while you are in any drawing command by holding down the mouse and dragging away from the point of interest.
There is more information here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#constructionlines
Having such lines appear in an automatic way works well for sparse drawings when you are drawing just a few lines like you show there. But when things are denser it becomes frustrating because your working area fills up with snaps all over and it can interfere with freely placing a point. So to avoid that MoI is intentionally designed to not do those automatically, only when you generate a construction line which can be done with a quick gesture inside any drawing command.
9100.253 In reply to 9100.1
For the SubD conversion feature is it expected behaviour that when the NURBS objected generated has a boolean subtraction performed on it in MOI the edges generated from that can't be filleted without errors?
I'm trying to work out if I'm making a mistake or just expecting too much from the feature.
Andy
9100.254 In reply to 9100.252
thanks for the detailed response! Sorry, I hadn't got deep enough into the docs yet. The construction lines function is such an elegant approach to this concept.
Rock on,
T
9100.255 In reply to 9100.253
Hi Andy,
Well it depends on the situation. In general that is not expected, however also filleting in MoI can have problems with complex chaotic geometry and it is pretty easy to have complex chaotic geometry with SubD conversions.
Is it possible for you to post the model so I can take a look at it? If you want to keep it private you can e-mail it to me at moi@moi3d.com, if it is very large you would need to use a file sharing service like Dropbox/OneDrive/etc... and send just a shared link through e-mail.
9100.256
Helo dear Micheal & dear users of Moi3D 4.0 (beta) ...
Is it possible, to import an OBJ too but without SUB-D?! Any possibility to set the strength of the build-in-SUBD? And for some OBJ Objects I dont want have SUBD ... e.g. if I import a pose from DesignDoll - nice tool for posing, but the poly-mesh-structure is very weird, lot of tris and so on - SUBD will not work well or much too long.
I try also the old MaxSmirnov Plugin _ImportOBJ it still works in 4.0 too, but in my eyes not very perfect, because if I import with _ImportOBJ the edges of each polygon are not welded, they are naked.
EDITED: 25 Feb 2019 by LORDFOX
9100.257 In reply to 9100.256
Hi Lordfox,
Sorry, no not with any built in tools. An OBJ file without Sub-D is a faceted polygon mesh model and MoI is not designed to work with that kind of data for modeling. You would need to use a polygon mesh modeling program to import and work with that type of data, not MoI.
Sorry, no not currently, it just uses the standard Catmull-Clark approach. At some point in the future I do want to add some edge weighting options but that would be unusual to do that directly in the OBJ importer.
> much too long.
That model data is just not suitable for use in MoI in general - it's not what MoI is focused on working with.
Show messages:  1-17  …  178-197  198-217  218-237  238-257  258-264
