V4 beta Oct-17-2018 available now - SubD to NURBS conversion
 1-10  …  151-170  171-190  191-210  211-230  231-250  251-264
Message 9100.191 deleted 20 Dec 2018 by BEMFARMER
Not a big deal, but:
Unless I am mistaken? I've noticed this morning that the f.lux program, which warms up Windows programs screen colors, during darker parts of the day,
SEEMS to be causing the Area Zoom Pan Reset panel at the bottom center of the MoIBeta4 screen to remain lighter than the f.lux colored MoI screen,
whenever the mouse pointer is in the gridlines area of the screen. This is not happening in MoI3.
(Hovering over the panel, the colors seem to match.)
So it seems like, for that area, the shade used by MoI does not reflect the f.lux modification?
9100.193 In reply to 9100.190
Hi Jörg,
> Is it a new feature? I never see this before.
No, that's the same as it has always been.
For the crash is that something you can repeat over there using that file you posted?
If it was just a one time random crash you might try updating your video driver since the crash report showed the crash was happening in video driver code.
9100.194 In reply to 9100.192
Hi Brian, re: f.lux - there is a difference from how MoI v3 and v4 handles that bottom viewport toolbar, in v4 it is a separate window layered on top since that was easier to do cross platform. So I guess that is affecting f.lux.
9100.195 In reply to 9100.194
Uninstalled f.lux, and highlight problem went away. Snagit no longer suffers brownout either.
Re-installed updated f.lux, and no more problems.:-)
After a reboot, my MoI4 hotkey for Light node editor reverted to its prior value, so I must have the MoI3 version of hotkeys reloading?
I updated the Ctrl+Alt+N hotkey in MoI3, for Light node editor scheme, and all seems to be well now...
EDITED: 21 Dec 2018 by BEMFARMER
9100.196 In reply to 9100.195
Hi Brian, by default MoI v3 and v4 both use the same moi.ini file where your shortcut keys are stored. So they will have the same shortcuts between them.
If you want though it is possible to make each of them use a separate moi.ini file and so have separate settings. To do that you can either pass the path to a moi.ini file as a command line parameter to moi.exe, or you can move the moi.ini file into the same directory as moi.exe and it will find it there but if you do the second one you would need to run moi.exe with elevated privileges ("Run as Administrator") because at the default privilege level Windows will prevent programs from modifying files in the "Program files" directory.
9100.197 In reply to 9100.196
Thank you Michael.
My home computer (seems) to have voluntarily switched to using (non-appdata) MoI3 files of type .ini and nodeeditor, for MoI4beta,
or else it has been that way for 9 months or so until I recently updated nodeeditor in appdata...
Changing one shortcut key in MoI 4 did not update the MoI3 .ini, (??)
I changed the Ctrl+Alt+N for Light Scheme nodeeditor in MoI3, and now the hot key works in MoI4.
Last night I updated nodeeditor in C:\Program Files (x86)\MoI 3.0, and now nodeeditor again works in MoI4beta.
I do not recall if MoI3 can use the appdata folder for customui and nodeeditor...
So I am still confused...
I'll puzzle on it some more.
I really like the appdata method.
p.s. Everything seems to be working properly with the office computer.
9100.198 In reply to 9100.197
Hi Brian, well one other complication is that settings are only saved to moi.ini when MoI shuts down.
So if you have MoI v3 and MoI v4 open simultaneously and make different changes in each one, they will have differences at that moment but the last one that you close will win out and have its settings in the moi.ini file.
Does that explain what you are seeing?
9100.199 In reply to 9100.198
Thank you Michael.
That makes sense.
Anyway, I'm using MoI4beta 99% of the time so I'll keep the MoI3 .ini the same as MoI4beta's.
Yes, your explanation is correct.
With MoI4beta closed, I opened MoI3, and changed the CTRL+Alt+N shortcut key by adding ZONK before the final semicolon.
Closed MoI3. Opened MoI4beta. The shortcut key alerted finding "ZONK,' and did not load nodeeditor.
Removed ZONK, closed and reopened MoI4beta, and the hotkey worked to load nodeeditor Light scheme.
The Light scheme is more printer toner friendly...
9100.200
Hi All
Have not been around for a while, just noticed the subd to Nurbs feature, I'm impressed.
Did a great job with my test model. the subd came from DazStudio, quit a complicated model.
Cheers, stephen
9100.201 In reply to 9100.200
Hi stephen, that's great thanks for testing the SubD to NURBS conversion. There are also some tune-ups coming for that in the next beta release.
9100.202
I am using the Volume Calculator script that we did with Max a few years ago (http://moi3d.com/forum/messages.php?webtag=MOI&msg=7421.61) with the latest beta and i noticed something strange:
When i call the script through a Keyboard shortcut it takes about 2-3 times as long to finish calculations as opposed to calling directly (<TAB> and type the command).
When i try the original version that i did (first page of the same thread ) the running time is the same.
I'm guessing that this has something to do with the optimizations that Max did, but I'm reporting it anyway, in case this affects more scripts.
Dinos
9100.203 In reply to 9100.202
Hi Dinos,
> (http://moi3d.com/forum/messages.php?webtag=MOI&msg=7421.61) <...>
I do see that the one in the link above is a beta 09-22 version and there is a later 9-27 version at http://moi.maxsm.net/media/files/ . So that might be worth a try.
Both keyboard shortcuts and typing in command names end up going through the same command launching mechanism so I don't know why one would be slower or faster than the other. Maybe there's some kind of file caching involved and it was more dependent on which one was done first rather than what the launching method was.
9100.204
I understand what you are saying and you are right of course, so it could be something specific to my setup.
Still, please try the latest version of the CVolume2 script from Max's site with the attached test file.
On my computer (Macbook pro 15 2015 16GB, running Mojave and MoI v4 beta Oct-17-2018) i get consistently around 2 sec of calculation when i type <TAB>_CVolume2 and around 5 sec when i use a shortcut.
I dont think caching is involved as i get the same results if i launch the script 2 or 3 times in a row using the same launching method.
I have this issue only with this script as i get the same running times if i use my original version of the volume script.
Unfortunately i dont use any other scripts that take a noticeable time to finish so i can't verify this with anything else.
Dinos
9100.205 In reply to 9100.204
Hi Dinos, I tested your file over here with _CVolume2 from CVolume.v.2.0.2015.09.27.zip and I get the same 3.5 seconds with both launching from a shortcut key or by typing in the command name.
Could you please double check exactly what you have in your keyboard shortcut? Are you certain it's not running some older version on the shortcut key?
I also tested putting some fillets and booleans onto your shape so it took longer for the calculation and still got the same times between shortcut key or typing in the command name.
EDITED: 22 Jan 2019 by MICHAEL GIBSON
9100.206 In reply to 9100.204
Hi Dinos, also how are you checking what is in your shortcut key, are you using the UI in the Options dialog or looking directly in the moi.ini file possibly?
9100.207
here is a screenshot from the shortcuts ui and the same line from my moi.ini file, [Shortcut Keys Mac] section:
Shift+V=_CVolume2 /*! Volume */
The complete shortcut section of my moi.ini is attached below.
The _Cvolume script is in: ~/Application Support/Moi/commands and its the latest version.
I've also double checked that there is no other copy of the script in the commands folder of the Moi.app folder.
This is very weird as the behavior that i'm describing is very consistent on my system and fully reproducible..
Perhaps its somehow macos specific?
Dinos
Size: 18.9 KB, Downloaded: 68 times, Dimensions: 870x62px
9100.208 In reply to 9100.207
I would suggest updating the shortcut key & latest script version, in MoI3 as well.
9100.209 In reply to 9100.207
Hi Dinos, well with your shortcut key of:
that's going to run the _CVolume2 command and pass "/*! Volume */" as a command line parameter to it. So that's different than your other launching method of just typing in _CVolume2.
The _CVolume2.js script happens to look at the command line for an optional angle value to use for the triangulation step. With the command line you are giving it, it's thinking you are requesting a 0 degree angle which will internally get converted into the minimum allowed angle and that will make for a much denser mesh thus taking additional time.
If you set your shortcut key to just plain _CVolume2 exactly like you are typing in you should then get the same result with the 2 different launching methods.
9100.210
that makes perfect sense so thanks a lot for your help to get to the bottom of this!!
I never though of looking for a parameter to Max's script although it did look like it was doing more work when it was slower.
I fixed the shortcut and the performance is now identical :-)
Dinos
Show messages:  1-10  …  131-150  151-170  171-190  191-210  211-230  231-250  251-264
