helix precision
All  1-2  3-4
9097.3 In reply to 9097.2
the amount is small, but I had a problem when I made a sweep of triangle with helix rail and tried to make a boolean operation with a cylinder with a same diameter as my helix. I'll try to create a file
9097.4 In reply to 9097.3
Hi glmr, the sweep itself goes through a refinement process. For the boolean it's best to have it push a little bit through the cylinder you are using instead of trying to make it skim right along the same surface area. It's harder for booleans to get a clean intersection on surfaces that just barely graze each other.
Show messages: All  1-2  3-4
