Moi3D to MagicaVoxel
 1-13  14-33  34-44
Selection stay of course valid for any other function! ;)
Here like Repeat z 6 (by button or by console)
Matrix will be modified to maxi 126 * 126 * 126
Theorical number of Matrix: 16 * 16 * 16 = 4096 !
Only with these little 3 videos we have to the end of Univers for explore possibilities! :)
Some speedy :)
The trimming can be made between each function by a simple clic on the red form!
(not made here)
EDITED: 9 Dec 2018 by PILOU
Intersection
- M (All mode Region All Voxel)
- Selection green object
- Ctrl (Move green object)
- Shift + Click on blue object
- Ctrl + X or Delete
Union
- Ctrl + Move (blue, green)
- Click on blue light object
- I Color as you want!
My Moi French Site My Gallery
Cylinder
- primitive Circle ...extruded (aTtach Face)
For a tube: can be a boolean Diff between 2 cylinders but this is more funny! :)
-Selection top
- function on console "ero xy"
- aTtach Face with Shift or not following you want erase or create to the deepth wished
EDITED: 11 Dec 2018 by PILOU
A complete process :)
Cylinder - Repeat xy 4 - Erase Voxel Sphere 20 - Scale 0.2 - Repeat 5 - Render
How to ? :)
Matrix by default 40 40 40 - Cube - 2 Lines (straight) - eRase - Face - X(Ctrl+1) - Circle under the base - eRase - Face - Z (Ctrl + 3)
Circle on lateral face -eRase - Face - X(Ctrl+1) - repeat 5 - Ctrl on the object for glide on Z for move the circle hat!
(all by buttons and/ shortcuts)
and all we have to do is play with the rendering parameters!
For the rendering and position of the camera it's up to you! :)
Colours/thickness of edges, grids, transparent materials, lighting, elongations on x,y,z, Stereographic projection!
120 above or 220 as follow for example for Stereographic projection
In one minute it's settled!
Only with this kind of shape it is the infinite possibilities!)
The longest one is actually the rendering time: 20 seconds depending on the machines and the size of the image!
EDITED: 20 Dec 2018 by PILOU
2 variants added at the Pseudofractal by Kchapelier https://github.com/kchapelier/pseudofractals-voxel-shader/tree/master/shaders
Of course you can make pseudofractal of pseudofractal! :)
not made here!
A new very cool fonction! ;)
9096.42
These are really beautiful... I love the aesthetic. It's very dreamy, retro and abstract.
9096.43
I can't let the stage only for Frenchy Pilou here. ;)
Everytime when I need an organic structure for MagicaVoxel, 1st step is always Moi3D.
Here the base model and the resulting renders in MagicaVoxel ...
Very poetic! Bravo!
And the other way : go from voluptuous surfaces of a moment of inspiration to the strict cuboïd world! ;)
But who can be also very evocative!
Take a look at this artist!
Here by Mari K https://www.artstation.com/madmaraca
By Mari K
Show messages:  1-13  14-33  34-44
