Moi3D to MagicaVoxel
 1-2  3-22  23-42  43-44
do you have also contact with the Developer of MagicaVoxel?
I ask because i was wondering why MagicaVoxel Viewer can read
.schematics files and why not MagicaVoxel? This would be imho
cool too, if MagicaVoxel could read them as well, then there would be
no need for the workflow you show.
9096.24 In reply to 9096.23
@Stefan
sure ...but...
No contact...it's a mysterious coder! :)
You must have twitter for some improbable contacts!) https://twitter.com/ephtracy
The thing the more uncomprehensive is that MineCraft (who has millions of players) has not a decent OBJ to schematic!
it's not the spirit to use something yet built!
And till now you must make that i made!
And it's not entierely perfect because if you use too biggest files (like ZBrush file) you have some luck to have no success!
We are waiting Zarbuz a French coder for that but it's not it's present priority! :)
And i have not yet test the colors of an OBJ to shematic...
Adventure continues...:)
Ps Magicavoxel knows to load OBJ but for the moment only in 126 * 126 * 126 matrix so some decreasing resolution! ;)
Ephtracy will maybe change that when you see these images
https://twitter.com/ephtracy/status/1049117436124024832
EDITED: 30 Nov 2018 by PILOU
thanks for the info, much appreciated!
With a ZBrush object a little more complex :) : No problem !
Thx to Patrick Min (Binvox) & Zarbuz (SchematicToVox) and of course Ephtracy!
next time i will play with size of cube - i will see some parameters inside BinVox...
1.4 millions cubes
From free SketchUp 2017 with a plugin by SdMitch : you draw any horizontal surface et voilà! :)
Low Tide :)
EDITED: 1 Dec 2018 by PILOU
And of course infinite variations of some stereoscopic variations...
Message 9096.29 deleted 2 Dec 2018 by MKDM
9096.30 In reply to 9096.28
This is really beautiful!
I like this kind of panoramic mood.
Very good camera point of view. Bravo!
Something very important that I just discover! :)
You can make Boolean Diff without use Patterns!
Just draw an object in a free space and with a different color of the object to trim!
And not make like me a selection inside an existing object!
2 weeks or more for discovered that! I am amazed that nobody tell me that! :)
A boolean union will be jut to colorize the objects with a same color! ;)
This can be enabled!
Can be partial!
9096.32 In reply to 9096.31
Thanks!!
And the cool thing is that can be "Multiple" & "Mono" or "Multicolors"!
(M) + Shift for reselect when trimming is done by the first click on the cutting objects!
Ctrl on a face for move the selection!
My Moi French Site My Gallery
Selection stay of course valid for any other function! ;)
Here like Repeat z 6 (by button or by console)
Matrix will be modified to maxi 126 * 126 * 126
Theorical number of Matrix: 16 * 16 * 16 = 4096 !
Only with these little 3 videos we have to the end of Univers for explore possibilities! :)
Some speedy :)
The trimming can be made between each function by a simple clic on the red form!
(not made here)
EDITED: 9 Dec 2018 by PILOU
Intersection
- M (All mode Region All Voxel)
- Selection green object
- Ctrl (Move green object)
- Shift + Click on blue object
- Ctrl + X or Delete
Union
- Ctrl + Move (blue, green)
- Click on blue light object
- I Color as you want!
Cylinder
- primitive Circle ...extruded (aTtach Face)
For a tube: can be a boolean Diff between 2 cylinders but this is more funny! :)
-Selection top
- function on console "ero xy"
- aTtach Face with Shift or not following you want erase or create to the deepth wished
EDITED: 11 Dec 2018 by PILOU
A complete process :)
Cylinder - Repeat xy 4 - Erase Voxel Sphere 20 - Scale 0.2 - Repeat 5 - Render
How to ? :)
Matrix by default 40 40 40 - Cube - 2 Lines (straight) - eRase - Face - X(Ctrl+1) - Circle under the base - eRase - Face - Z (Ctrl + 3)
Circle on lateral face -eRase - Face - X(Ctrl+1) - repeat 5 - Ctrl on the object for glide on Z for move the circle hat!
(all by buttons and/ shortcuts)
and all we have to do is play with the rendering parameters!
For the rendering and position of the camera it's up to you! :)
Colours/thickness of edges, grids, transparent materials, lighting, elongations on x,y,z, Stereographic projection!
120 above or 220 as follow for example for Stereographic projection
In one minute it's settled!
Only with this kind of shape it is the infinite possibilities!)
The longest one is actually the rendering time: 20 seconds depending on the machines and the size of the image!
EDITED: 20 Dec 2018 by PILOU
2 variants added at the Pseudofractal by Kchapelier https://github.com/kchapelier/pseudofractals-voxel-shader/tree/master/shaders
Of course you can make pseudofractal of pseudofractal! :)
not made here!
A new very cool fonction! ;)
9096.42
These are really beautiful... I love the aesthetic. It's very dreamy, retro and abstract.
Show messages:  1-2  3-22  23-42  43-44
