elipse question
All  1-4  5-6
909.5 In reply to 909.4
Hi Pilou - any 4 points will make a curve that is made up of 4 different ellipse segments I think, not just one single ellipse.
Here is one trick you can use to deform a circle by 4 corner points, which is to create a trimmed surface and then move the surface points around.
Start by drawing a plane (not a rectangle, but a filled-in plane from Draw solid / Plane):
Now draw a circle centered on the plane:
Trim the plane by the circle, then select the resulting disk surface and turn on control points with Edit / Show pts:
Now the points can be adjusted and the circle trim curve on the surface will deform as the underlying surface is stretched around:
When you're done, you can extract the trim curves as a regular curve object by selecting it and using Edit / Copy then Edit / Paste.
> There is not function "Ellipse tangent" in the future?
Often times these kinds of calculations are more difficult with ellipses since there are more variables to define, like 2 different radius values instead of a single radius. This makes for a large number of different proportioned ellipses that can fit tangent to 2 curves.
909.6 In reply to 909.5
Thx for the tricky trick of the "trim plane(not rectangle) by circle" !
It always the more simple things that work better ! :)
Show messages: All  1-4  5-6
