Export Points from object into txt file
 1-12  13-32  33-40
9071.33 In reply to 9071.32
Hello ! Absolutely, here is more context :
https://www.youtube.com/watch?v=4Mtun8PgbfQ
On this example I am working with a bunch of curve objects (a total of 10) that will be exported to points data using SavePointFile as per the topic of this thread. It is a trivial thing to do when dealing with only a single curve object, but the selection process becomes quite tedious when working with multiple - as one often ends up selecting full curves, which in turn leads to a selection buffer than does not get converted to standalone points. You'll see me fight against that in the clip.
So from there I was wondering if there was any way to automate this conversion process - that is to say, running some sort of "extract points" command, operating on multiple objects at once.
(CurveArray can be a good workaround at times but in my case here it is not practical as the curve objects are already optimized and are crafted with as few points as possible).
I hope this makes more sense !
9071.34 In reply to 9071.33
Hi pior, are the curves you show there all polylines where they're all made up of line segments? And the points you want are the points of the polyline, not any more added to the interior of any curve segments?
> objects at once.
Yes it should be possible but it would help if you could post an example .3dm file that has an example of an input and expected output for the "extract points" mechanism that you need.
That would help me to know what kind of points you want to be created.
There are many potential ways, like do you need points evenly spaced by distance across the curves? Points at just the ends of segments? Points along a bendy curve by some angle metric? The control point hull of the a bendy curve? ... ?
9071.35 In reply to 9071.34
Hello -
Yes the input objets are as "raw" as possible in my case, all made of connected straight segments (as per processed once by a DXF export, or as drawn manually point by point). And then the goal would be to get the points copied out of these objects, ready for SavePointFile.
I personally have no need for bezier control points in this process, and no need for any resampling of points either as the points have all been manually placed for the objects to be as clean and lightweight as possible.
Here is a file with a before/after :
https://drive.google.com/file/d/1WKKFvrZKFJr3GZavhIFN9Mgzad3E-yN9/view?usp=sharing
I hope this makes sense !
9071.36 In reply to 9071.35
Thanks pior, please try the attached command. Select your polylines and then run ExtractPolylinePoints and it should generate those points and select them so they are ready to be exported.
9071.37 In reply to 9071.36
Points will be exported at what format ?
9071.38
Hello Michael - that's excellent ! This is working perfectly, and saves quite a bit of time and error. Loving how the selection is automatically ready to go. Thank you so much, as always.
@FP : the export format discussed in this thread is simply .txt, formatted as what is called "CSV" (comma separated values). This is a very simple database format that is very useful for all kinds of applications. For instance online bank accounts can be downloaded as such and then manipulated with spreadsheet software, data processing/visualisation applications, and so on.
In the case of the SavePointFile from this thread the export is simply XX,YY,ZZ on each line like so :
And from there one can do all kinds of stuff with the data. In my case I am converting it to a series of segment lengths and angles fed it into a drawing robot. This allows me to speed up the drafting of full scale sewing patterns.
https://www.youtube.com/watch?v=yobpxLgDAr4
So again a huge thanks to Michael (and the person originally asking the question about exporting points to CSV) as the information and help in this thread was exactly what I needed. Being able to export the data directly from MOI is truly excellent.
EDITED: 24 Sep 2021 by PIOR_O
Size: 670 KB, Downloaded: 56 times, Dimensions: 954x531px
9071.39 In reply to 9071.38
You're welcome pior, I'm glad that will be useful! That's a cool project with a real life Logo/turtle drawing robot set up!
9071.40 In reply to 9071.38
Thx for the infos and bravo for the robot!
Show messages:  1-12  13-32  33-40
