How to add a curve to a loft?
All  1  2-4
9069.2 In reply to 9069.1
The more simple :
draw your 4 th curve like this you will see exactly where drawing it / existing surface
kill the previous surface lofted
Select the 4 curves
call Loft
Careful : if you select the 4 curves one by one : order is important!
If you select them by box selection normally you will obtain a progressive surface
EDITED: 24 Sep 2018 by PILOU
9069.3 In reply to 9069.1
Hi Nico, thanks for your purchase!
Currently there isn't any way to add an additional curve to an already completed loft using history. To do that you would need to delete the loft result and make a new one that has all 4 curves in it.
In the future I do want to work on deeper history editing functions but it will be quite a lot of work so I'm not sure when that will happen.
Thanks, - Michael
9069.4
Thank you for your answers.
Show messages: All  1  2-4
