Brachistochrone Problem
All  1-11  12-16
9065.12 In reply to 9065.7
Great link about the skate ramp Pilou, and all your other links.
9065.13 In reply to 9065.12
Maybe you know him, it was a SktechUp Master! ;) Jeff Hammond
Now I believe that he uses Rhino or Moi ;)
By Jeff Hammond
EDITED: 23 Sep 2018 by PILOU
9065.14 In reply to 9065.11
2 curves are in tangency as soon as 4 control points following are aligned!
My Moi French Site My Gallery
9065.15 In reply to 9065.11
Hi Yakas,
The existing CycloidInterp script will work, with aRadius = bRadius = 2.5 feet+, mirrored upside down, using half of one cycle.
At a radius of 2.5 feet, the height difference is 5 feet, and the upper tangent is 90 degrees.
At a radius of 3 feet, the height difference is 6 feet, and with one vertical foot removed from the top of the cycloid,
the tangent is about 65.9052 degrees from the horizontal, as measured with Michael's Angle script.
Some more options may be added to the script...
(No calculus needed. It has already been proven that without friction, the brachistochrone is a cycloid)
(The CycloidInterp script uses the Trochoid formula. When aRadius = bRadius, the trochoid is a common cycloid)
EDITED: 23 Sep 2018 by BEMFARMER
9065.16 In reply to 9065.15
Great!
Thanks so much.
Show messages: All  1-11  12-16
