Please tell me about this features ( blend & network )
All  1-3  4
906.4 In reply to 906.3
Hi Lish - that was created using Construct / Loft.
I didn't use a guide for that one - in MoI the Loft command is for creating a surface through cross-sections without any additional guide curve. Using a guide curve as a path in MoI is called the "Sweep" tool instead of Loft.
Here are the steps - first I drew 3 curves in the side view (I used the Right view this time), using Draw curve / Freeform / Control points:
Then I switched to the 3D view so I was looking at the curves like this:
Then I dragged the curves apart to position them:
Then select all 3 curves and run Construct / Loft:
The hole was cut by drawing an additional curve in the front view and then selecting the surface and running Edit/Trim to cut the surface with the new curve.
Show messages: All  1-3  4
