New Beta version will not open my large files
All  1-10  11-20
9054.11 In reply to 9054.8
I like the display mesh angle setting... use it regularly.
If you remove it from the gui, can we keep an ini setting for it?
9054.12 In reply to 9054.11
Hi Burr, part of removing it could involve changing the whole approach, something along the lines of using a rough angle initially and then doing a more detailed one in the background. It will be a while before I'll be able to look into that though.
If I do end up having to remove the current one at some point because of too many people getting tripped up by it I will make sure to keep it available to script and in moi.ini though.
9054.13 In reply to 9054.12
Thanks Michael...
Message 9054.14 deleted 4 Oct 2018 by MICHAEL GIBSON
9054.15
This issue is something that I hit quite regularly.
Would it be possible to have the Mesh Angle value displayed somewhere on the ui?
www.jameselliott.co.uk
9054.16 In reply to 9054.15
Hi James, it would be possible to modify the UI to display it, where would you want to put it?
I'd generally recommend not to mess around with that setting much though since it can have bad side effects if set lower than the default 10 degrees.
9054.17 In reply to 9054.16
Maybe between the options and the help at the bottom.
9054.18 In reply to 9054.17
Hi James,
So to do that you'll need to edit the file CommandBar.htm which is inside MoI's ui sub-folder.
The options and help buttons are on line 137 of that file and look like this:
				<moi:CommandButton icon="icons/OptionsIcon.png" onclick="if ( event.ctrlKey && event.shiftKey ) { LlamaMode(); } else { moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' ); }"><moi:Text textid="Options"/></moi:CommandButton>
				<moi:CommandSplitButton icon="icons/HelpIcon.png" menu="HelpMenu.htm" onclick="moi.launchHelp();"><moi:Text textid="Help"/></moi:CommandSplitButton>
To add a display of the mesh angle between them insert this new line in between them like so:
				<div style="display:inline-block; margin:0.5em">Mesh angle:<moi:Text binding="this.innerText < moi.view.meshAngle"/></div>
9054.19 In reply to 9054.18
Thanks Michael, works a treat!
Message 9054.20 deleted 13 Oct 2018 by MICHAEL GIBSON
Show messages: All  1-10  11-20
