Hi motorbk, if you move the slider all the way to the left when you export, it will make a file with 16,000 polygons in it which is a pretty small file.
That looks like this:
You can also use the Angle type in field to make a rougher angle than what the slider is limited to. Expand the dialog with the little down arrow and then put in an angle value of 75 degrees for example. That will make just 5,511 polygons, it looks like this:
If you need even fewer polygons than that I would recommend using a mesh reduce function in a polygon modeling program. There are also some standalone mesh reducer programs you could try like this one: https://www.atangeo.com/ .
