V4 beta Aug-28-2018 available now
 1-3  4-23  24-43  44-63  64-65
9044.4
I have just tried a multi part assembly all parts are named when I import into SolidWorks all names are lost and coming up just as part numbers anything that needs to be changed in the options?
9044.5
Cool! Thanks, Michael for the new beta!
Going to install it right now. I'll be back if I encounter anything.
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
9044.6 In reply to 9044.4
Hi Alex, is this new behavior? If you use the previous MoI v4 beta or v3 does it behave differently?
Also what file format are you using for the transfer?
Another question is do you see the same behavior with a simple case like if you make 1 box and assign a name to it does that go through or not?
MoI always writes names to STEP format exports, there isn't any setting for enabling or disabling it.
9044.7
I use STEP to go from MOI to SW never had any problems with parts name and colours they usually port fine use it all the time. Here is a simple STEP export same file one from V3 and another from V4.
9044.8
WOW!
3 to 4 times faster 3dm loading and display on my iMac
Thats BIG!!
9044.9 In reply to 9044.1
Hello Michael!
How are you? I hope fine.
Thanks for this new improved beta.
After downloading I did just a very quick loading test with a middle size 3dm file.
Unfortunately I have first uninstalled the previous beta, so I can't compare the new results with older one, but this new beta it's significantly faster than the original 3.0!
Also the display engine seems to be much more fast and fluid than version 3.0
My config: i7-7700K 4.5Ghz with (only) 4 cores, 32GbRam 3000Mhz, Nvidia Gtx 1080 Ti overclocked.
The 3dm file I have used for the test: about 196MB
You can download it at: https://grabcad.com/library/ngoc-mai-tug-boat-1
And these are the results of my loading test:
Moi version 3.0 :
Mesh angle set to 10.0: loading time about 26 secs
Mesh angle set to 5.0: loading time about 39 secs (total memory occupied by Moi: 2.5 Gb), rotation of the maximized 3d viewport is pretty slow
Moi version 3.0 :
Mesh angle set to 10.0: loading time about 7 secs
Mesh angle set to 5.0: loading time about 11.5 secs (total memory occupied by Moi: 2.51 Gb), rotation of the maximized 3d viewport is MUCH MUCH MORE FASTER!!
VERY WELL!!!!
Now I hope to see a new antialiasing routine for the meshes rendered into the viewports (not for the curves or the edges but for the boundaries of the surfaces, that are still very jagged). I think that leveraging on the GPU power we should not have bad performance.
And...before you ask :), changing the antialising settings with the Control Panel of the GPU doesn't lead to no improvements.
Thank you very much!
Tested with some large files on my WIN10 6 core PC. Very fast and smooth!
9044.11
9044.12
Thanks Michael
www.jameselliott.co.uk
9044.13 In reply to 9044.7
Hi Alex,
Can you please post the STEP files that you used to make those screenshots?
Also is this new behavior that has started in this just released V4 beta or does the previous V4 beta behave the same way? If you don't have the previous v4 beta installed any more please e-mail me at moi@moi3d.com and I'll send it to you.
Thanks, - Michael
9044.14
Thanks Michael!
Excellent speed increase on loading!
Edit:
Tested with Rotation script on 300mb file..
Ver.3.0 = 135 ms
Ver.4Aug28 = 30 ms! 8-)
EDITED: 29 Aug 2018 by SBEECH
9044.15
Hello,
Significant consistent performance increase on load and display, awesome work.
Thanks everyone for testing it - I'm glad the performance updates are working well!
I have also updated the first message with the list of bug fixes and change for this release.
9044.17 In reply to 9044.16
Thanks Michael !
9044.18 In reply to 9044.16
My Moi French Site My Gallery
9044.19
Just about everything seems to work fine so far in the new beta.
"Mac version multiple windows - Add "Window" menu to Mac version top menu. Shows all open files and allows switching between them easier. Also support Cmd+Tilde (Cmd+~) and Cmd+Shift+Tilde for switching to next/prev window."
Very convenient, thanks. That was one of the few advantages of the previous Wine-based Mac version of MoI.
"Mac AMD performance - fix problem with default buffer location with OpenGL on some AMD cards that was causing slow redraws on some machines like iMac pro."
The latest MoI V4 beta runs smoothly on my Mac. There's only one minor behaviour that occurs when panning in the viewports: as soon as the pointer nears the border of a viewport, the panning accelerates, causing the scene to quickly disappear out of view. If this doesn't occur using a mouse, then it might be related to the Wacom Intuos (Pro Medium) I'm using (latest drivers installed).
Also, I assume you've heard that Apple is ceasing OpenGL support in an attempt to motivate macOS coders to adopt their Metal library. I've heard that Metal is quite competent, but I fully understand that it's a nuisance for coders to be forced by Apple to add support for it.
What are your thoughts about Metal support? The Blender developers are planning to move to Vulkan and add a Metal wrapper for macOS, while AMD has jumped in and already added full Metal support in their free Radeon ProRender renderer.
Regards,
Metin
visualization • pixel art • illustration • animation • 3D design — https://metinseven.nl
EDITED: 30 Aug 2018 by METINSEVEN
9044.20
there was a discussion about that some time ago
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8964.1
quote:
But there are a couple of reasons why this is probably not a big problem for MoI.
One is that MoI does not require advanced OpenGL functions, it's not like I've been blocked by anything while waiting for them to update to a new OpenGL release level. It seems likely that they will freeze it at the current level and not just outright remove it, we'll see.
The other is that MoI v4 is well positioned to switch to Metal if necessary because part of the MoI v4 rewrite was to use a graphics library called BGFX which supports multiple rendering back ends. So MoI v4 does not make OpenGL calls itself directly, it makes calls into BGFX and then BGFX handles the OpenGL stuff. On Windows MoI calls into BGFX and BGFX uses Direct3D11 functions. So MoI's own viewport drawing code is well separated now from any specific graphics API.
BGFX also has a Metal rendering back end as well. I haven't tried using it yet because it was officially at WIP level when I started using BGFX and also Metal is only available starting on macOS 10.11 while I wanted to support older OS versions than that for v4. I might wait to try it until I'm comfortable requiring 10.11 as the minimum supported platform which is simplest but there is some possibility I could figure out supporting Metal only on 10.11+ while still supporting OpenGL on older platforms. I haven't dug into that yet. But anyway there is a pretty straightforward path to getting MoI to use Metal.
..upps, just saw, that your posted in that thread as well, but on a different matter...then just as a reminder ;D
EDITED: 30 Aug 2018 by MARCO
9044.21 In reply to 9044.19
Hi Metin, thanks for testing it!
That sounds like the autopan function, it's so you can continue to pan in one direction without having to start a new motion.
It starts when you're a little ways out from the border and when it has started you can leave the cursor right in that spot and it will continue panning without any motion required but if you continue to move it closer to the edge it will speed up.
If it is bothering you it is possible to disable it in moi.ini under:
[View]
DisableAutoPan=y
re: Metal, there is some previous discussion on that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8964.3
The main thing that is bothersome about it to me is it isn't supported on older OS versions. Metal only works on 10.11 or higher, and currently MoI supports 10.8 and up. I'll probably look into it some more when I'm ready to bump up the minimum OS version that MoI supports running on. I don't really expect to gain much with a switch over though, MoI already does a good job of batching things up so things like lower driver overhead is not likely to make any difference for my particular case.
So it is annoying in the sense that it will involve doing some work for no particular benefit.
If it helps Apple make higher quality drivers then that could be a benefit though. That's why MoI doesn't use OpenGL on Windows. On Windows MoI uses Direct3D11 primarily because the drivers for it tend to be better tested and overall high quality.
Thanks, - Michael
9044.22 In reply to 9044.21
DisableAutoPan has solved the panning behaviour, many thanks Michael. If you'd get a penny for everything you've solved here, you'd be a millionaire. :)
And I suspected I had already discussed the Metal issue here, but as I also did at the Blender forum and ZBrush forum, my memory failed me. :)
I fully understand your arguments regarding Metal, and like you mentioned MoI already runs smoothly in its current incarnation. Apple will undoubtedly include OpenGL for quite some time to come, just will not support it anymore. So you will have plenty of time to make a transition when you're ready for it.
Regards,
Metin
9044.23
Have tested in MoiV4 June and same problem with STEP export part names are lost when imported into SW.
Here are all the files.
EDITED: 23 Dec 2023 by ALEXPOLO
Show messages:  1-3  4-23  24-43  44-63  64-65
