Constant Viewport refresh?
All  1-2  3-5
9039.3 In reply to 9039.2
Hi Michael, I don't mind performance impact. I'am fully aware it will eat a lot of resources. But anyway I need to sometimes enable render loop.
Can you share how-to do so?
9039.4 In reply to 9039.3
Hi Fubax, well I really don't recommend it but you could try inserting a some script like this inside of CommandBar.htm :
		<script>
			var g_intervalID = null;
			function constantRedrawTimerFunc()
				moi.ui.redrawViewports();
			function startConstantRedraw()
				if ( !g_intervalID )
					g_intervalID = window.setInterval( constantRedrawTimerFunc, 300 ); // call timerfunc every 300 ms.
			function stopConstantRedraw()
				if ( g_intervalID )
					window.clearInterval( g_intervalID );
		</script>
Then set up 2 shortcut keys with:
script: moi.ui.commandBar.startConstantRedraw();
script: moi.ui.commandBar.stopConstantRedraw();
The call to moi.ui.redrawViewports(); will not immediately draw the viewports, it will mark them as needing an update and they'll get redrawn when the message queue is next emptied.
9039.5 In reply to 9039.4
Thank you Michael, it works. I only had to use it temporally so the implementation is very nice.
Show messages: All  1-2  3-5
