self intersections
All  1  2-4
9029.2 In reply to 9029.1
Hi glmr, can you please post the .3dm model file with your object in it?
9029.3 In reply to 9029.2
sure
9029.4 In reply to 9029.1
Hi glmr, thanks for posting the file. For this case I'd recommend splitting the object into 2 pieces and using Edit > Trim to cut the pieces with each other.
I first used Edit > Separate to break the object into individual surfaces, then used Edit > Trim with the "Isocurve" option to split the self-intersecting surface into 2 pieces. Then I used Edit > Trim using those surfaces to cut each other, then Edit > Join afterwards. See the attached 3dm file for the result.
Booleans will be a little difficult in this case because the self-intersecting area has some little slivery pieces poking through:
Show messages: All  1  2-4
